Question about Whirlpool AWM8143 Front Load Washer
Fault code fh on awm8143/1
Please help i have a whirlpool awm 8143 which is not completeing a wash cycle the message on the display is FH - this means that there is not enough water in the machine .I have cleaned out all the filters and checked all the pipes and they are not blocked,could this be a problem with a circuit board?any one got any ideas what is causing this problem ,Thanks
  • bick Aug 21, 2007
    Thanks for trying I did post a comment as it wouldn't allow me to rate. I checked all hoses and pipe work ok, also checked over the pressure switch and pressure switch hose and all seemed ok. I have had the machine for a while so I decided to just treat the wife and buy a new one! Much appreciated for trying
    Cheers bick.
I have a similar problem turns out my cold hose is blocked, any way of unblocking it? is it the yellow filter in the main head?
Posted on Aug 15, 2010
  • 5,911 Answers
Two questions: Is there water in the tub? Or...is the tub empty? If there is water in the tub you need to check the following: 1. Verify that you do not have a siphon problem. This is caused by placing the drain hose too far into the drain standpipe and/or sealing the top of the standpipe. This will cause water to constantly empty as the tub tries to fill. You need to have an air gap for proper drainage. 2. Check your pressure switch and pressure switch hose. 3. Make sure the drain pump is operating correctly. 4. Check operation of flow meter. This is what actually detects the water flow coming into the machine and causes the error to flash if the proper conditions on are not set. It will detect the AMOUNT of water entering the tub and it detect the pressure switch trip that shuts off the supply when the tub is filled. If there is no water in the tub you need to check the following: 1. Check your fill valve screens. Turn off the water and remove the hoses from the back of the washer. The fill valve screens are inside the hose connections on the back of the washer. It only takes a small amount of debris to restrict water. You can clean them out using cotton swabs. 2. Make sure your fill hoses are not kinked or clogged. Check the easy possibilities, first. I suspect you may have either a siphoning problem, or clogged fill valve screens. If you check everything and still have problems, I would replace your fill valve before suspecting a defective pressure switch or flow meter. Let me know if this helps.
Posted on Aug 18, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 21, 2007
    You never answered any of my questions. Did you try anything I suggested? Have you come up with a solution of your own? Is there anything I can do to still help? It would be nice to receive feedback as to why the advice given wasn't acceptable, so that I may try to assist you better.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool awm 8103/s keeps stopping during cycle with code FH displayed? any suggestions
Whirlpool's 'FH' stands for 'no water inlet' (but goodness knows how 'FH' could mean that!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 04, 2011 | Washing Machines
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
If after 30 seconds the control does not detect water entering machine and then valves
will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow sensor has
detected 48liters of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash.
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
315 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
