Question about GE WHRE5260E Top Load Washer
Washer stops and make clicking sound
My washer stops and makes cliclikg sound when 6 mins left for the cycle to be completed i.e. before rinse,I stop the washer,and turn the selector to quick rinse then it works fine.what could be the reason,can u plz. help
  • 883 Answers
Sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation. if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
Posted on Aug 18, 2007
SOURCE:
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    My front load washer won't spin it stops at 6 min left
    Good Morning Friend,
    I understand that your Electrolux washer will not complete the spin cycle, and stops with 6 minutes left. I will be more than happy to assist you. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I please ask that you leave the model number of your washer in your response. Hope this is helpful.
    -Best Regards-
    WP
    May 30, 2014 | Electrolux Washing Machines
    Washer stops cycleing
    First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
    Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
    Stop frequently on spin and rinse cycle F6 code
    I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
    Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
    LG tromm washer stuck in rinse cycle
    • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
    Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
    Whirlpool washer stops after agitation cycle
    Maybe check the belt is it cracked worn or fibers showing if so replace it
    Jul 26, 2009 | Whirlpool Washing Machines
    Maytag Washer Not Completely Rinsing
    If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
    Just a suggestion.
    Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    GE WHRE5260E Top Load Washer Logo
    107 people viewed this question
    Top GE Washing Machines Experts
    Marvin
    Marvin
    geapptech
    jimorris77
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
