Question about RCA P46810LV 46" Rear Projection Television
Power, volume buttons
I have to hold the power button in for about 5 minutes and then the tv finally comes on.I have to unplug the tv to turn it off. You have to push the volume button in for about 2 minutes and then you can adjust the volume.
  • roro1 Aug 17, 2007
    It is on the tv.
  • roro1 Aug 18, 2007
    One more thing. When i program the remote it only works for a few hours.
  • 84 Answers
Is this on the remote or the buttons on the TV?
Posted on Aug 17, 2007
SOURCE:
My blue power light is on but tv will not come on.and cant power the tv off
Try unplugging the tv from the wall for 5 or so minutes. Plug it back in and turn it on. If it works, fine...if not then look for a small hole marked "reset". Put a straightened paper clip in it and push slightly until you feel the button. Push and hold for 30 seconds and let go. See if that doesn't fix it.
Jan 04, 2014 | Panasonic VIERA Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
TV (#N3760W) won't turn on (immediately).
sounds like the board connecting to the power switch going bad. are you using remote?
Oct 17, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
Fix my tv
unplug it for 5 to 10 minutes
make sure the reset button isnt pushed in or sticking as the reset button might be the problem
plug it back in & turn it back on
hope that fixes it for you
Sep 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Can not turn off power lock
hold volume up and menu buttons at same time for 10 seconds - under left edge of tv
Jun 15, 2009 | ViewSonic N2230w 22 in. LCD TV
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
