Hi. trying to get the wiring for 110 in my waterway pool pump
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
SOURCE: 1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
SOURCE: Hi I have a Waterway
Thank you for posting your question here on Fixya.com. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
You will need (2) 6203 sealed bearings and a 1000 mechanical seal. They should be available at a local electric motor repair shop for less than $20. You may want to ask them for pointers on installing them or consider having them do it for you if you are not familiar with changing bearings. The cost is easily outweighed by the assurance it is done right. You are also unlikely to have the necessary tools unless you have worked with these items in the part.
A typical shop repair for this would be under $100 parts and labor.
John
SOURCE: I have just bought a
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside for both the 110 or the 220V convertions.
