i was using compaq visual fortran 6.5. i un installed it due to some reasons. when i tried to re install it doesn't accept my cd keys and says "you have enetered an invalid serial number" although the key is working one. i am stuck.......kindly helpppppppppp....... rambo
-   I am having the same problem. re-installing XP SP3 did NOT work. I'm trying to get 6.0 installed so I can do the 6.5 then 6.6 upgrades
-   tmcorrigan
Mar 27, 2009
-   When I try to install Compaq Visual Fortran 6.6.a, I get error message that I am using the wrong serial number. I know that I have entered the correct serial.-   Blast_61
Same error here. Compaq Visual Fortran 6.5/6.6. I think is a problem related to Windows XP SP3.
- Solution: Re-install Windows XP SP3 (integrated). Right after installation (no reboot) run the CVF installer. It will work. Then do normall installation stuff. If you have Windows XP SP2 you won't have any problem. Hope it helps.
Couldn't find ANY solution with SP3 installed before CVF installation.
I had the same problem, and finally it turned out that it was my antivirus McAfee which blocked the access. To resolve it, I temporarily disabled "Access Protection" at the McAfee VirusScan console, then I successfully installed Compaq Fortran.
I get "microsoft visual studio has stopped working" whenever I try to run CV Fortran 6.6....
(More)
I get "microsoft visual studio has stopped working" whenever I try to run CV Fortran 6.6. I'm not sure what to do about it. Thx
i am an administrator user but i get the message "setup was unable to create the program folder...
(More)
i am an administrator user but i get the message "setup was unable to create the program folder 'compaq visual fortran 6'" on 96% of CVF 6.6 setup progress. could any body please help me?
i hav pro. in stalling of my compaq visual fortran. actually i took it from my teacher in zip file...
(More)
i hav pro. in stalling of my compaq visual fortran. actually i took it from my teacher in zip file format , whn i extract it thr was 4 folders named axp , f90_sql etc now whn i try to run the setup it was showing invalid for win32 application n i also wanna know wht setup i hav to run.
Hello, I have a problem installing Compaq Fortran 6.6 on Windows Vista. I installed it under...
(More)
Hello, I have a problem installing Compaq Fortran 6.6 on Windows Vista. I installed it under administrator account, but when I tried to open the Developer Studio, a windows popped up with the following message: "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available" and it does nothing and the program can't be opened. I would appreciate any ideas or suggestion on how to fix the problem.
