Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Fridge frozen solid
My fridge is frozen solid! The temp gauge says 6 and won't go any higher and everything inside is froxen solid. The freezer is -18. Can you give me a clus as to what might be going wrong? Thanks!
  • 3 Answers
Usually on refrigerators, the highest setting makes it coldest and the lower settings are warmer, relatively. "6" on my dial says "coldest" - Perhaps this is the case for yours? Let's hope it is that simple
Posted on Aug 17, 2007
Rge 400 fridge freezer purchased 2011
try moving the temp prob down on coils inside or let hang if same unplug thermistor in back let run overnite if ok replace thermistor
Jun 16, 2014 | Dometic Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Refrigerator freezing items
turn the setting inside the fridge to 5 or 4....make sure its not an upright freezer....thanks and have a great day
Nov 08, 2009 | Refrigerators
We had a power outage, after power back up, the fridge is getting super cold, milk is frozen, we make the fridge temp higher, doesn't help
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
In my Frigidaire fresh compartment everything is ?frozen. Can somebody help me what to do?
Adjust the fridge compartment temp to a higher setting it should be located at the top of the frige inside. Should be a dial that has numbers on it this dial needs to be turned to higher number to prevent this from happening.\
Good Luck
Dave
Sep 15, 2009 | Freezers
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
Sep 03, 2009 | Refrigerators
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
313 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
