Question about Ricoh Aficio 250 Copier
Copies & Faxes come out solid black
First the faxes started having wide stripes. Then they print solid black (full page). Then the copies started doing the same. For awhile, I was getting an SC306 error. I cleaned what I could (vacuumed) and replaced the Photoconductor Unit (PCU). I thought that fixed it, but the problem returned after just a few copies.
  • Anonymous Aug 21, 2007
    Based on some other information, I've ordered what I think is the "Charge Roller Home Position" sensor. I'll have it tomorrow, will install it, and will report my success or failure. Then, if that didn't work, I'll try bprimm's suggestion.
  • Anonymous Aug 22, 2007
    After much troubleshooting, I believe I found the problem. With the Error SC306 being reported, I had purchased a service manual. That error said...
    The charge roller home position sensor does not detect the on condition.
    - Possible causes -
    o Charge roller home position sensor defective
    o Charge roller contact clutch defective
    So, I finally found the sensor and got the information from it. The item replacement part number (by Sharp) is GP1A073LCS, and the item can be purchase for < $2 at www.digikey.com. I purchased one and installed it, and things seem to work now.
    Bprimm, thanks for all your help!
Sounds like a charge problem, check the clutch that moves the charge roller to contact the drum. The clutch is on the back of the machine. Brad
Posted on Aug 19, 2007
SOURCE:
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Black stripe down right side of incoming faxes and copies, cleaned view window but still there and actually got worse.
pull your drum unit out and look at the top of it. you will see a blue plastic tab. that tab has got to be all the way on the left side. if not, it will cause a black stripe about 3/4" wide.
hth,
razors
Mar 03, 2010 | Brother IntelliFAX 4100 Laser Fax
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Cannot clear memory--NEED FOR WORK ASAP!!!!!!!!!!!
Out of Memory message
If the memory becomes full while you are making copies, the LCD
message will guide you through the next step.
If the Out of Memory message appears, press Stop/Exit to
cancel or Black Start or Color Start to copy the scanned pages.
You will need to clear some jobs from the memory before you can
continue.
To gain extra memory, you can turn off Fax Storage.
—OR—
Print the faxes that are in the memory.
When you get an Out of Memory message, you may be able
to make copies if you first print incoming faxes in the memory to
restore the memory to 100%.
Apr 07, 2009 | Brother MFC 420CN All-In-One InkJet...
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
Ricoh Aficio 250 Copier Logo
323 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
