Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Indeset d63 dishwasher
Fills okay starts cycle then trips curcuit breaker if l turn dial past this point runs okay until drying cycle checked heating element got contiuaty
The heater is faulty Regards Engineer
Posted on Aug 18, 2007
SOURCE:
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
My child put dish soap in the washer and the suds have leaked through the door onto the floor. How do I clear up the suds from inside the dishwasher? This also caused the circuit breaker to trip and I...
Turn off curcuit breaker. Mop up suds and water with towel. Remove kick panel mop up water here and dry out with a fan. Replace Kick Panel. Reset Curcuit breaker. Add one cup of Vingar to bottom of tub. Run a rinse and hold cycle. Repeat if necessary.
Sep 11, 2011 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishwasher keeps tripping the electric it works after a day or so then it happens again, its a year old we cant see any leaks etc so not sure what to do
Hummm, well something is wrong. What else is on that curcuit?
In terms of breakers, once they start tripping, they trip FASTER. Consider replacing it.
if the problem persists, do an amp draw test on the dishwasher. Heated drying is a higher amp draw.
Nov 01, 2009 | Dishwashers
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
Idesit dishwasher
it sounds like the element isnt working properly.locate the element connections by removing the lower kick panel and turn the unit on to the drying cycle.use a volt meter and check the voltage.if you have voltage there than turn the circuit breaker off remove the wires to the element and check with the meter for continuity,let me know.
Nov 10, 2007 | Indesit 24 in. D63 Free-standing...
DW trips cicuit breaker
I have seen a lot of these older dishwasher break the wires running up to the timer. the break right near the bottom of the door where they flex when you open and close it. I would turn of the power, remove all the torx screws along the inside edges of the door, as well as the 2 on the bottom edge of the door facing up (you cant see them, just gotta feel around for them) and loosen the 2 on the top of the door near the latch ( so you can tilt the control panel out to remove the outer door) follow the wires from the timer down to the bottom of the door and see if any are broken or missing insulation. If not, take the bottom panel of the dishwasher as well and locate the 2 terminals hooked to the heater and check them with an ohmeter to see if they are grounded to the frame of the dishwasher. the dishwasher may be doing a heated rinse just before the dry cycle even though you have low temperature and no heated dry selected, so the problem may still be the heater. Good Luck!
Dec 12, 2006 | Asko 1385 Dishwasher
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
189 people viewed this question
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
