Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
BEKO FRIDGE HI I HAVE A FRIDGE FREEZER AND IT IS ALWAYS LEAKING AND SMELLS BAD I WONDERED IF I HAVE GOT IT ON THE WRONG TEMP SETTING ? ANY ADVICE WOULD BE GREAT THANKS
  • Noosaville Mar 14, 2008
    Same Problem in Leibherr Fridge sectioin.
    Drip/evaporation tray becomes foul smelling with sludge preventing evaporation. The poor design of this tray means it can not be removed for simple cleaning. Worse still after a painfully slow cleaning exercise, two months later the problem re-appears.
    Problem is suspected to have begun with some food or spill of fridge product that has passed througg the condensation drain at the inside rear of the fridge
    Novelist:
  • 87 Answers
Leaking what? And where from. If it is water inside you have a blocked drain if on the floor then you may have a hole in the pan on top of the compressor. If not water I have no idea?
Posted on Aug 17, 2007
I have a beko frost free fridge freezer its only 18 months old and Ive got a build up of ice in the fridge. all my food is getting frozen and Ive got my temp dial down to min .cant understand what cou
Is the door seal working correctly? If the door has become distorted slightly it might be letting in moisture via a gap in the door seal which will result in the build up in ice.
If you can see ice build up leading from the door area, this will give you a clue to where the seal may be faulty. Check that the door is squared up to the freezer with a spirit level and if required gently bend the door back into place by holding the corner with your feet and adjust from the other corner.
Oct 07, 2014 | Beko CDA670FS 280 litre Frost Free Fridge...
Fridge always running. Refrigerator freezes food at lowest setting.
Here's the manual you need with the parts lists. http://www.hammerwall.com/Download_Manual/37232/ On the first page, it has "parts" numbers for the other manuals you may need that I'm sure you could also find online with a Google search.
Here is the website that carries the part: http://www.needapplianceparts.com/218673008.aspx You might be able to find the parts elsewhere online.
Jan 22, 2014 | Frigidaire FRT21H8 Top Freezer...
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Fridge not Woking but freezer is what is possible causesBeko fridge freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Beko CDA670F (9 cu. ft.) Bottom Freezer...
I have a stainless GE profile PSS26SGPASS side by side fridge and suddenly the freezer and fridge wont hold the temp settign I put. The fan works, the controls work to lower the temp setting but it isn't...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 26, 2011 | GE Refrigerators
I have a beko fridge/freezer, the freezer is working but the fridge is not, help!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 21, 2011 | Refrigerators
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
422 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
