Question about Motorola Mobility H700 Headset
Not Pairing with Razr
I am having problems with setting up my headset. I am unable to get it to connect with my phone.
  • 1 more comment
  • umpire fred Dec 20, 2007
    LOST Insructions Manual, MOTOROLA H700, iI need to match up my phone with it.
  • ladyhawk919 Jan 28, 2008
    Having problems connecting my motorola h700 to my motorola bt50 phone.
  • Anonymous May 07, 2008
    It can not find the device
    President:
  • 1,114 Answers
There is an online guide from Motorola on how to pair with your phone, there is also a FAQ section. Link: http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=36f01f79696c9010VgnVCM1000008206b00aRCRD Go through the guide and let us know if you still have an issue & detail the problem. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 17, 2007
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Unable to pair Emerson em227 headset with RAZR
I'd be looking at the bluetooth settings on the phone since you found it with the Samsung. That tells me that the bluetooth section of the headset is working properly.
Jan 23, 2018 | Cell Phones
Pairing my Motorola Razr with my Motorola H12 Bluetooth Headset
-put the headset2.gif in the covered charger (not plugged in)
-hold down all 3 buttons for at least 10 sec
-leave headset in charger (unplugged) and enter in 0000 when prompted for pin.
Sep 04, 2008 | Motorola Mobility RAZR V3
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility H700 Headset Logo
41 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
