I have a Sony TV model KV-2167MT Trinitron.I'm facing problem while switch on from front switch Standby LED blinking while press any switch Like Volume up down, program up down. but power not on. I replaced 2sd1878 and PS801. it work 30 minutes after that transister get short again I change tr. but problem is same. Tr. 2sd1878 short after 30 minutes. I check output voltage 110V DC is normal. Any one have solution. please reply...
Dry solder in vertical out put section & Vertical ic LA7830
Posted on Jan 20, 2013
Maybe the problem why d1878 busted is due to defective FBT
Posted on Feb 15, 2012
I have sony trinitron KV-2167MT, when i power on the screen display line in the center only?please help me out as soon as possible?thank you
Posted on Jun 28, 2011
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Posted on Aug 18, 2007
Again, you must be sure to use an original Sony horizontal output transistor and you must resolder the pins of the horizontal DRIVE transformer, not the flyback transformer. The horizontal drive transformer is the little transformer that is connected to the BASE of the horizontal output transistor, with 4 working pins. The flyback is the large transformer connected to the COLLECTOR of the horizontal output transistor, with many pins arranged in a circle. The little drive transformer has one or more large resistors near it and the little drive transistor. Be sure to solder all pins of that little transformer and ALL parts near and around it, and all parts between the little transformer and the output transistor, as well as all damper diodes, safety caps and yoke connector pins. If you have resoldered all of those and used original Sony parts and the set still fails, it is time to take it to a qualified tech familiar with Sony sets.
Apr 08, 2013 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Jan 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Aug 13, 2007 | Sharp 32C-240 32" TV
Jul 18, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Nov 06, 2010 | Sony FD Trinitron WEGA KV-20FS120 20" TV
331 people viewed this question
Hi MikeNJ1964,
I replaced original Sony Transister and resolder the pins of the horizontal driver transformar and near area printed circuit board. But it not help me again transister short after few minutes.
Please suggest what to do???
Thanx,
Jatinder
Hi MikeNJ1964,
I try with above mention solution. first i clean all PCB and re-solder all component near to Horizental output section and observe more then two hrs. Know set is working fine.
Thanks a lot for given valuable tips.
Jatinder
9811196073
Jatinderbajwa@yahoo.com
