Samsung SF-560 Plain Paper Laser Fax
Problem for Samsung SF-560 Plain Paper Laser Fax
Speed dial list
By tatum on Aug 17, 2007
How do you activate the speed dial list?
Best Solution
posted on Aug 17, 2007
Very Helpful)
xetas
Rank: Wiz
Rating: 89%, 113 votes
***Storing a Number for Speed Dialing***
1 Press Phone Book on the control panel.
2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display
?Store&Edit? on the bottom line of the display. Press Enter.
3 Press Enter when ?Speed Dials? appears on the display.
The display prompts you to enter a location number, showing the first
available number.
4 Enter a one or two-digit speed dial number between 0 and 79, using
the number keypad or scroll button (􀂥 or 􀂊), and press Enter.
If a number is already stored in the location you chose, the display
shows the number to allow you to change it. To start over with another
speed-dial number, press Upper Level.
5 Enter the number you want to store using the number keypad and
press Enter.
To insert a pause between numbers, press Redial/Pause. A ?-?
6 To assign a name to the number, enter the name you want. For details
about entering characters, see page 1.14.
If you do not want to assign a name, skip this step.
7 Press Enter when the name appears correctly or without entering a
name.
8 To store more fax numbers, repeat steps 4 through 7.
To return to Standby mode, press Stop/Clear.
***Sending a Fax using a Speed Number****
1 Feed the document(s) face up into the ADF.
For details about loading a document, see page 2.2.
2 Adjust the document resolution to suit your fax needs. See page 2.3.
If you need to change the darkness, see page 1.20.
3 Enter the speed dial number.
? For a one-digit speed dial number, press and hold the appropriate
digit button.
? For a two-digit speed dial number, press the first digit button and
hold the last digit button.
The corresponding entry?s name briefly displays.
4 The document scans into the memory.
The fax number stored in the speed dial location is automatically
dialed. The document is sent when the remote fax machine answers
Comments:
Aug 17, 2007
- I uploaded the manual for the SF-560 as well, it should be available after it is approved.
Was this helpful?
Yes
No
Popular Solutions for Samsung SF-560 Plain Paper
Questions and Unsolved Problems for Samsung SF-560 Plain Paper
Do you recommend Samsung SF-560 Plain Paper Laser Fax?
Answer
Answer
No readable print at receiving end. Copy of letter comes out dark grey with no print on it. No... (More)
Answer
Hi i have a sf 560r and when i change the toner it beeps and says jam or cartridge empty? help!
Answer
lost manual and I need to add more quick dials to the fax
Answer
our fax machine does not allow any faxes to come through and we have checked all the settings for... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machines Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
