Question about Canon FAXPHONE L80 Laser
Spring off A small spring is off. I have the part. Need a diagram/schematic to find where it goes. Can't find documentation.
  • Anonymous Nov 14, 2007
    same thing...found spring loose inside. now the darn thing won't recognize that there is a toner cartridge installed
    Scholar:
  • 159 Answers
The spring is probably from the toner cartidge. This machine takes a FX3 cartridge. There is guard on the cartridge that shield the drum from damage as you insert and remove the cartridge from the machine.Look on the top right hand side of the machine and you should see a hairpin style spring. If it isn't there, then thats probably it. Now this guard piece relies on the spring for proper operation of the cartridge as it uncovers the connections that mate with the ones in the machine. Also as you insert the cartridge, an actuator lever is depressed that tells the machine there is a cartridge present. You will have to replace the cartridge to make the machine work if you can't relocate this spring properly.
Posted on Jan 20, 2008
Water is coming out where the cleaner is suppose to siphon from. Do you have a schematic of how that port should be , i.e the small spring and the bearing?
If water is coming out, then you just need to reverse the spring and ball bearing (swap them around). Right now, the spring is where ball bearing should be and this is keeping the ball bearing from seating against the o-ring inside. Shouldn't take more than a few minutes. Usually, the small end of the cone spring goes against the ball bearing.
May 07, 2014 | Coleman Garden
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
Where does the guard return spring go back on when it comes off ?
Hi the small spring goes back inside the guard . It is hard to explain how to do this and quite fidley, i had a similar problem with a dewalt saw when the spring flew out. I have included a Parts Breakdown diagram so you can see where the spring goes (item number 53)ckjoiner.jpg. Hope this helps and you get it fixed.
Jan 13, 2011 | Makita BCS550 18V Lxt Lithium Ion 5 3/8...
Rear spring bushes, (front of leaf spring) navara
Throw me an email at cyreyes1@hotmail.com
and I'll email you a copy of the Service manual for the Nissan Maxima 04, I have it as a WinRar compress document and also can be extracted using WinZip and so you'll ve able to see it as PDF to view and print out the only section u need, you'll have diagrams for all electrical to mechanical.....
The fast you do it the fast you'll get it....
Feb 25, 2010 | 1992 Nissan Pathfinder
I am tryin to find a diagram or schematic for a maytag jet clean
i was able to obtain a drawing from repair clinic that helped to resolve my problem.
Feb 07, 2010 | Dishwashers
Need diagram for rear brake spring assembly on a 1994 toyota tercel
The bottom spring should be hooked into a small hole on thefront shoe bottom, and to the adjuster cam on the other(rear) shoe. The remaing two spring are one long and one short. The shorter spring goes from the front shoe to the post and the longer spring goes from the rear shoe to the post. Just a suggestion, when you are dissasembling anything complex like this, it's a good idea to take a few digital pix along the way. Good luck my friend,Dana P.S. if you haven't taken the other side apart yet you can use it for a reference only mirror the assembly.
Sep 06, 2009 | 1994 Toyota Tercel
Replacing indicator/dip /cruise control stalk 86 dodge daytona
SOUND LIKE THE CANCEL SPRING FOR THE BLINKERS GO TO AUTOZONE OR NAPA WEBSITE PUT IN YOUR CAR INFO AND TYPE IN TURN SIGNAL SWITCH ? IT WILL SHOW YOU A PICTURE OF THIS SPRING
Aug 24, 2009 | 1986 Dodge Daytona
Waltec washerless faucets
i cant draw it for you but the spring fits inside the seat and the seat goes in the hole last. in the hole goes the spring then the seat goes on top then the stem.put the seat on a small screw driver,then the spring then slide it all into hole, try it good luck.
Mar 13, 2009 | Plumbing
Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Dec 10, 2008 | TDK TC-30HG VHS-C Tape
Canon FAXPHONE L80 Laser Logo
74 people viewed this question
old marine
old marine
