Question about Nintendo 64 Console
Connecting n64 using attenna cable
Hi my n64 is working properly but when i use just my antenna cable i cannot find the channel it is on how do i set this up properly and is there a problem
Should be channel 3 or 4 and does it has a RF selector switch?
Posted on Aug 17, 2007
SOURCE:
Sony bravia no digital channels
If you've tried different antennas did you attempt to re-tune/re-scan for additional channels after switching? For digital channels to be detected they must be scanned for, so consult your manual on how to perform an automatic scan of the digital channels available in your area.
Mar 27, 2014 | Televison & Video
Attenna warning light
Is showing a bad swr which will only happen when transmitting. Get a swr meter and patch lead and tune your antenna for the lowest swr on channel 20 or middle frequency of your rigs frequency coverage. Easy fixed.
Jan 12, 2014 | Uniden Pc76xlw 40 Channel Cb
I am thinking of purchasing this tv for a person who doesn't have an outside attenna and is too poor to purchase cable or a dish program. Can this set, a 22in. 720p model, work with an inside attenna? Is...
Any TV that has a Coaxial input can connect directly to an RF antenna. If this person lives near a large city, its likely they will receive more channels than if they live somewhere remote. Perhaps an antenna with a powered Signal Booster will improve the signal. Neither are included so I think Radio Shack has a good selection.
Jan 17, 2011 | Coby Televison & Video
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I'm hooking up a Nintendo 64 to a AOC LCD L32W861 television. I am trying to use an RF cable to connect the two systems. For whatever reason, the tv responds to the connection, but simply displays "No...
If you have it connected properly,it probably has to do with tv station select.Do you know how when you do a channel autosearch and it picks up cable anddigital channels?Well if you go into that menu,on my tv it shows 4 different possibilities.The first set is labeled DTV,second TV,third Cable DTV,fourth Cable.You may have to switch to the plain TV option and use channel 3 or 4 in that mode,because everything else is looking for a digital input,and N64 is not digital.I used to repair Nintendos for a full time job too.If that doesn't work,I am providing a link to N64 FAQ's and it may need repair,probably the RF cable or the RF transmitter within the console.I am thinking the TV solution will work though.
Good luck and game on! Greg
http://www.nintendo.com/consumer/systems/nintendo64/index.jsp
If you have more questions,maybe about how to set up the TV,just comment here and I will get an auto email with a link.
Aug 24, 2010 | Video Game Consoles & Games
N64 isn't working with Vizio HDTV...
Do this, hook it up to another tv just to make sure that the N64 is workig properly. If it works on another tv then you know the system is fine. If it doesn't work on another tv then it could be that you have dirty games and you need to clean the contacts and then reinsert them into the system and get them to work.
Keep the system on a known good working tv until you can get your games to work and display properly. You can clean the games by using a damp q-tip and wiping the contacts on the bottom of the game back and forth a bunch of times, there will probably be all kinds of black that comes off.
keep on trying games untill you get one to work and display properly, then go ahead and move the tv to the one you want it to work on and test it out and it just might work then.
Jun 26, 2009 | Nintendo 64 Console
N64 connections
make sure your tv is tuned to either channel 3 or 4 check the rf adaptor with the coaxal cable going into your "antenna" jack and make sure that its connected tightly as well make sure there is no bends or breaks in the cable as well.
you may also want to find some gamecube A/V cables since they will also work to replace that RF adaptor and right now ushally they are on sale in department stores and places like GameStop and EB Games.
Dec 27, 2008 | Nintendo 64 Console
Weird message on the tv
Just letting the TV run for about ten minutes while it "thinks" seems to be the best answer. The more I tried to do, the longer it took. But just letting it stay on and sit for a bit it eventually switched over to static, and from the static I was able to get back to the channell with cable.
Dec 24, 2008 | Sanyo Vizon LCD-15A2 Television
2nd remote has trouble changing channel
hook up a 6 foot peice of coax cable to the remote antenna port and then attach a barrel connector and then use a larger antenna "bunny ears" basically to extend distance of uhf signal for remote
Nov 27, 2008 | DISH Network DVR-625 DTV Receiver /...
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Nintendo 64 Console Logo
150 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
