Question about Canon CanoScan D1250U2F Flatbed Scanner
CanoscanD1250U2 I previous used the scanner with OS Windows XP with no problems. On my new computer I have Windows Vista and even after following all instructions from the CANON website and updating the drivers, my scanner will not work. I receive the following error messages. "This application needs elevation" and User Account Security requests permission to open the programme each time, then asks me if I wish to resolve the problem online. This directs me back to Cannon's website. Even following all the support information after opening an incident number I still have no resolution to my prblem.
  • Canon Master
  • 12,061 Answers
Re: CanoscanD1250U2
I am fairly sure this is Vistas UAC, coming into play, I think you need to Elevate the Permissions to Administrator for it to Install and work. here is an explanation below. Sometime you must "Install" the software in "Compatibility Mode" also. You have to be an "Administrator" to do certain things in Vista and the User Account Control has to be setup correctly to work.
Posted on Aug 17, 2007
0 characters
3 Points
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
Need driver to install CanoscanD1250U2 on Win7
Unfortunately that scanner is not officially supported by Windows 7, but the Canon D1250U2 Vista driver may work for Windows 7 too.
Feb 08, 2011 | Canon CanoScan D1250U2 Flatbed Scanner
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
Sep 15, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Need a driver for canon canoscan N 65OU
I got this link from Canon's site. Click here. Choose the Operating System of your computer. Then download the driver utility. I hope this will work for you.
Jun 07, 2010 | Canon CanoScan N650U Flatbed Scanner
Cant use with windows vista there a way around
Some hardware can be run in compatibility mode. Download and install the Windows XP drivers from this website. If it fails, run the compatibility routine to see if it will fix the problem. The Vista OS may tell you to check for problems. Follow this to see if the OS resolves it for you. According to the Canon website, the newest driver is the XP one.
Dec 12, 2009 | Canon CanoScan N650U Flatbed Scanner
Have the drivers been updated for Visioneer Onetouch 8920 scanner
Below is a link to the list  of the only scanners that VISIONEER has written a Vista driver for(and not likly to write any more for former scaners.)  Your model in not on that list. Unless, for some reason , they decide to write a Vista driver,you will never bve ableo to use that scanner with the Vista  OS. No one else will ever write one either.     Please don't rate me badly for telling the whole truth even thought you may not like it.
The below link is where I took the followign from:
As Microsoft continues to release new versions of it's Windows Operating System, the requirements for peripherals and software change. Visioneer scanners are designed to leverage the tools and features included with the operating systems that are current when products are released. When feasible, we develop scanner drivers for new versions of Windows. On the day Windows XP was released, Visioneer had more scanners qualified to wear the Designed for Windows XP logo than any other scanner maker. In spite of our best efforts, major changes in the underlying architecture of Windows XP make it impossible to write new drivers for many of our older model scanners.   Visioneer posts the last release of drivers on each Product's Homepage and provides online support for older products. Scanners designed to work with older versions of Windows may not function properly after upgrading your computer's operating system.   We offer an industry leading upgrade program, giving a 25% discount from our online scanner store for customers that return their old unit to ensure proper disposal as part of our environmental recycling program. For details visit Visioneer's Trade Up Offer.
Jan 30, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Driver Problem
hi sir
i think i must try it in windows xp.
Sep 02, 2008 | Umax Astra 4450 Flatbed Scanner
Acer Scaner Pria 640P Flatbe -Driver needed for Vista home
Dear Sir
I have recently changed my windows vista operating system and my scanner which model number is 640P not working properly. the previous software under windows xp is not working. Please solve my prob. and a bundle of thanks for solving my prob. immediately.
zaheer babar
from lahore pakistan.
Aug 27, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Installing scanner on windows XP
it depends on the model of your scanner, some manufacturers have a subsequent driver for any windows OS platforms, for newer OS like XP and Vista sometimes it is available.
most likely if you will tell me what brand and model we should be able to find an appropiate solution for this
Jul 25, 2008 | Scanners
Not working on vista
Unfortunately, the manufacturer has not released a driver for that scanner to work with Vista. That scanner will only work with Windows XP / 2000 / Me / 98SE. The following link shows the list of scanners that Visioneer is making Vista drivers for:
May 03, 2008 | Visioneer 9020 Flatbed Scanner
Canon CanoScan D1250U2F Flatbed Scanner Logo
252 people viewed this question
Top Canon Scanners Experts
 Mike M
Mike M
D. E. Hev
Mohan Sriraman
Mohan Sriraman
Are you a Canon Scanner Expert? Answer questions, earn points and help others
