Question about Hitachi C29-F300B 29 in. Television
Hitachi C29-F300b television
Not powering up. I found the power chopper STR-f6456 was O/C destroyed by S/C zener diode D910 in the power supply. I think it is a HZS5B1 4.6 to 4.8v zener but I need to confirm. I've replaced the very expensive chopper but need the zenner to finish the job. Can anyone help me ID diode 910 in a Hitachi c29-F300b please? The diode is so tiny even under the scope its un-readable. Thanks from Rod
Thanks Larry I'm just a little reluctant to buy a manual to find one part in a TV repair for an elderly neighbor. Its a love job and proved more costly than I anticipated. I'll try everything I can to verify the part type first. The diode is about 30 cents US but I need to be sure of its type before I switch it on. I am very confident I have solved the problems in this set once I have the new diode in. good to hear from you and thanks for the input Regards from Rod
Posted on Aug 17, 2007
    Scholar:
  • 173 Answers
Found a sevice manual at manualsnguides.com but they asking 27 bucks, a buck something shipping. I dont have the manual or know a hatchi dealer closeby. good luck
  • larry hanson
    larry hanson Aug 31, 2007
    also call in the yellow pages ..."electonics wholesale" you should find one if not a small town....then ask for a power-suppy kit for that model no...amazingly they got in those kits all that can blow in the power-supply, diodes resistors , caps , output ic and transistors, ...if no luck locally look online ...
    good luck
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
My hitachi 29in ctv power supply 110vac had a problem on zener diode will blown if we switch on the tv. what spare parts to change so that the power supply zener diode will not blown again and the supply...
The secondary output voltage comes out from is more than it should be there. That is why, the protection zener diode blows off, as soon as you switch ON the set. First find and repair the power supply regulator, for correct output voltage. Refer its repair book for details. After repair include the zener diode in place. OK.
May 08, 2012 | Hitachi Televison & Video
Hitachi model # C29-F300b 29 in
Just went through this. What you need is an adapter between your cable and the TV:  Male European Cable converted to Female American Cable
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Male&Category_Code=
Hope this helps.
Jan 10, 2008 | Hitachi C29-F300B 29 in. Television
Hitachi C29-F300B 29 in. Television Logo
662 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
