Question about Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
Usb device not recogised
Hi I have the above corded gamepad, installed latest logitech software loads then ask's you to plug in gamepad then message appears to say usb device not recogised contacted Logitech they suggested that I performed a selective startup and before doing this uninstall logitech software and install after selected startup of which I have done but still not being recogised by windows any suggestions please
Re: usb device not recogised
Personally I believe its the motherboard as it works on other pc's that I've fried it on many thanks anyway
Posted on Sep 07, 2007
  • 133 Answers
When Windows does not recognise the device, it practically means the device is faulty to the point where Windows cannot even determine what sort of device it is, it can only tell that you've plugged something in and it doesn't know what. This is not down to compatibility, software issues or that it isn't installed properly. It is just a faulty unit. If it's within warranty, get it returned for a replacement or a repair - if it's not, don't bother with getting it repaired, it'd be quicker and cheaper to get a new one. Sorry to be the bearer of bad news - I test USB devices like these all the time and the situation is always the same when you get that error message from the system tray when you plug a USB device in.
Posted on Mar 03, 2009
0 characters
3 Points
Logitech software does not detect f710 gamepad
usually these gamepads are plug and pay why do u need a software?
Dec 30, 2013 | Logitech F710 Wireless Gamepad
Its not working but the computer does recognise the controller.
You need to calibrate the controller. Go to the Logitech website and install the latest drivers. This will include software which allows you to recalibrate your controller.
Hope this helps.
Jan 24, 2011 | Logitech Precision USB Gamepad PC Game...
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
Logitech Profiler does not detect my logitech dual action gamepad, why? I have a computer that uses vista 64bit.
Hi, Please uninstall any LGPS version present on your OS - Then please proceed to clean boot. -> Unplug any USB devices connected to the computer ( Less keyboard + mouse ) If you have a corded keyboard + mouse please use it rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software, plug the hardware when needed. -> Should work.
If a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If the problem persist, swap computer and try, if it does not solve then contact customer service for replacement
Thanks and have a nice day Julien
Apr 16, 2010 | Logitech Dual Action for Pc (963292-0403:)...
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Gamepad wont work
game pad is need to install in to yr pc 1 u have to install drivner then u plug yr gamepad to usb pord
Apr 02, 2008 | Logitech Rumblepad 2 Vibration Feedback...
How to install on Mac
Logitech does not provide any gaming software for the Mac platform. However, Logitech gaming devices are supported natively in Mac OSX. This means you can still use your Logitech gaming device, provided that the game you are playing supports a gamepad, joystick, etc.
If you are using a gamepad, and you'd like more programmability, you can use third party software such as Gamepad Companion. Keep in mind that this is third party software and you should contact the manufacturer of the software should you have any issues or questions about using the software.
Please read THIS and THIS as well.
Dec 22, 2007 | Logitech Extreme 3D Pro Joystick
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO ---
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
First, I'm going to assume this controller is usb and not wireless, blue-tooth, or gameport. Second, if you have a usb mouse or keyboard and it works fine, then its going to be that you need to find vista drivers for your device and install the drivers before plugging it in. If you have another usb device, try plugging it into the usb port and if it doesnt work either your computer is faulty or you need to update it. Vista is rather fickle when it comes to drivers and what not. Instead of windows coming out with the drivers, they let other people come out with them then they endorse those drivers. Try going to logitechs site, they are usually extremely helpful and easy to navigate. You can probably find drivers for your device easily. If you need any more help, let me know, I'll find you a few other solutions.
Sep 12, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Logitech  Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758) Logo
383 people viewed this question
Top Logitech PC Game Controllers Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Logitech PC Game Controller Expert? Answer questions, earn points and help others
