About a month ago we left to stay at a friends. Everything was working perfectly Wireless and all. Belkin Router is connected to a Westell Modell 6100 Modem. Get back today and the LAN works perfectly. But for some reason when we try to hook the Ethernet into the Router again, Nothing is working. Tried the reset nothing works. And 75% of the time we unplug and plug the router back it. It quickly turns on and off. the other 25% of the time when we do actually get it to stay on, the power light switches to the modem light and it is the only one active. The Modem is also not lighting up its little Ethernet light as well. I suspect the ROuter has gone poof. Done resets on everything.. even 2 brand new Ethernet routers. Please Assist?
Comments:
Mar 21, 2009
- I meant to put Brand New Ethernet CAT5 cables.. not Ethernet routers. heh please help
-   It was all working well, and now no light other than the power indicator is working and no connection happens. Neither wired connection nor wireless connectino works!
-   Guest
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Remove the router from the circuit. Power down the cable modem. Connect a pc directly to the cable modem (just one pc). Turn on the modem again and see if you can connect. You should be able to connect. If you can, it's probably the router. If not, it's the cable modem and possibly the router too. Try one at a time.
Is there anyway possible I can use my sprint wireless card on my ps3 by plugging it directly into...
(More)
Is there anyway possible I can use my sprint wireless card on my ps3 by plugging it directly into the usb port on the ps3 for internet access?
router is not retrieving ip address through modem, when connected to the modem i recieve net but...
(More)
router is not retrieving ip address through modem, when connected to the modem i recieve net but only local connection through router
