Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
Firewire port The firewire port on the camera is broken, I can no longer import video to the computer, does anybody know it can be replaced and how much this costs ? thx
    Champion:
  • 221 Answers
If the physical connector is broken, replacement cost for that part is about $30.00 (connector is mounted on a circuit board which needs to be replaced.) If the connector is good, but the firewire interface in the camera is bad, repair involves replacement of the main circuit board, which is between $400 and $500. These are parts costs, they don't include labor.
Posted on Sep 26, 2007
SOURCE:
Can't import to my computer, can my 1394 firewire port on the camera is bad
I would suspect the camera not the computer is the issue here. Have you tired it on a friends computer?
Aug 31, 2016 | Panasonic AG-DVX100BP Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
Trying to tranfer digital video camera video to my computer
Hi
I think you may need to connect the camera via Firewire, I've checked the specs of your camera and it seems to be minidv and has a firewire port. A lot of video editing software will not detect your camera unless it is connected via the firewire port. you need to check if your pc has one first of all you can do this by going to control panel/ network connections and see if there's an icon for 1394 Connection if there is then you have firewire, so you then need to see which type of socket it is on your pc and on your camera and purchase a suitable cable. Take a look here for a reference http://en.wikipedia.org/wiki/FireWire If you don't have firewire you can buy a firewire pci card that will slot into your computer which will contain 3 or 4 ports.
May 18, 2009 | JVC GR-D54E Mini DV Digital Camcorder
I need to import video from my canon zr500 to my pc
Hi!
You can import videos from your camcorder to your PC using a DV cable. Check this page from the user guide of your camcorder.
Basically, you need a firewire port and a DV cable. Most computers (new ones) already have firewire ports (or 1394 ports).
I hope that helps.
Good luck and have a nice day!
Nov 22, 2008 | Canon ZR500 Mini DV Digital Camcorder
Importing from Sony Handycam trv350 to iMovie
I have a TRV730, and on this camera the USB port on the camera only reads files from the memory stick. (Set the camera mode switch to "memory", and the Mac will display the contents within about 20 seconds.) Same as any digital camera.
Video in/out is only done through the firewire (iSight) port. You need to buy a 4-pin/6-pin firewire cable. Good ones are $25 or so, cheap ones can be had for $5 or less but you take your chances with those. (Can anyone explain why Sony includes a useless 4-pin/4-pin iSight cable with the camera??)
What's cool about the Digital8 cameras is that you can put in an old analog (Hi8) tape and output a digital signal to the Mac.
Can't be 100% certain of this, but I'd bet your camera is similarly configured. Squeezing video through the USB port would be painfully slow anyway.
Apr 16, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Im trying to import videos from my mini dv tape on my digital Video camera JVC GR-290u i plugged in a usb cord from my camera to the computer but nothing came up. when i switch from video mode to memory...
As it's a DV (Digital Video) camera you should use the IEEE 1394 Firewire socket if it has one. Then use a DV capture program.
If you dont have a Firewire port on your PC you can buy a card like this one which will connect you Camera to your PC.
http://www.amazon.com/D-Link-3-Port-IEEE-Firewire-Adapter/dp/B00004XRD3
Mar 13, 2008 | Cameras
Transfer video from tape to computer
mjtlj:
You will need a firewire cable to successfully transfer video from your tape to your computer. It also greatly helps to have a firewire port on your computer. Once you have connected your firewire port on your camera to the firewire port on your computer, you can use windows movie maker to transfer video to your computer. (File > Import for Digital Video Camera)
If this has helped you, please report this problem as fixed :)
Jan 08, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
239 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
