Question about Compaq Dot Matrix LA2 Printer
Give me the different kinds of error messages of sot matrix printer
THis my assignment Please help me, Give me the different kinds of error messages of dot matrix printer
0 characters
1 Points
Hello and Welcome to FixYa!
Sir/Ma'am kindly explain your query, Is your printer shows some error message or it just prints blank pages without any error message? Before the problem started have you replaced your Cartridge or something you did? Kindly give some detail about the problem you are facing. I will help you according to that.
I am here for your help. Waiting of your response.
Dec 04, 2011 | Canon imageCLASS D661 Digital Printer
PRINTRONIX P5005B. Morning Sir. Please I am using the printer referred above to print vouchers. The problem is that the pins code appears on the black field and are visible. Is there any settings i...
Does the pins code need to be printed at all? If not, then software should fix this.
If you need to print them, but perhaps in a second page, you might try adjusting the forms thickness lever forward a notch or two. You'll have to balance print quality against pins code showing.
Aug 31, 2010 | Printronix Line Matrix P5005B Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
What is error 16
There is an LCD Message and panel Light Status and a beep pattern which lights are flashing? Paper out? Pause? Tear Off/Set? Top Of Form/Set? Front? Rear? Turn off printer 4 five min then back on..what happens? error 16 means an unknown printer error.. with a dot matrix printer print head failure can cause different errors.
Mar 31, 2010 | Epson DFX-9000 Matrix Printer
Error 03 turn off printer
please check some cable connector if the theres some disconnections... inside the printer.
Jun 16, 2009 | Epson DFX-9000 Matrix Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Error 0E
head driver error:
chk carrier cable unit
worst ROM Board = service
Mar 12, 2008 | Epson DFX-9000 Matrix Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Compaq Dot Matrix LA2 Printer Logo
29 people viewed this question
Top Compaq Printers & Copiers Experts
john archer
Prashant  Sharma
Prashant Sharma
Are you a Compaq Printer and Copier Expert? Answer questions, earn points and help others
