Question about D-Link DP 303 (DP-303) Print Server
Can't print HI. Today morning,my printers decide not to print, and moreover, on the print server, the two LED's of "LTP 1 & 2" are both not lighting up. The link from the LAN is perfect. I would also like to know if i can log on to the printer, its ok ip - 192.168.0.50 Thanks.
Try unplugging the printer and router and restart them your ip- my be used by other device. quicway.com
Posted on Aug 17, 2007
SOURCE:
Print size a3
Print size A3 is decided by printer (tray) + printer driver.
A print server does not decide print size.
Jul 22, 2014 | D-Link Computers & Internet
Will not print Have installed the software but cannot print. I notice that an icon (Two blue screens) says network cable unplugged.is this relevant to the printer problem
if ur not printing on the network printer or shared printed of ur network, yes, but if so, of course you cant print. try this:
network: "ON" the network switch/router. check the network cable and other until that the unplug msg
disappear.
local:(PORT ON LTP/USB and IS NOT a TCP/IP PORT): 1. look at ur printer, it should be that the green led is ON ang no blink. RED led also denotes that empty ink and needs a replacement.
2. the installation cd must be compatible to ur OS
Mar 31, 2010 | HP DeskJet 5550 InkJet Printer
My 1290 has been working fine doing a lot of printing today. I have tried to print additional work but have alternative flashing red and green lights. I cannot replace the ink cartridges as it will not...
Hi
Not know if it will work for your printer but you can gave it a go.
Step 1: Manual Temporary
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT2_bing.gif)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Epson Stylus C46 InkJet Printer
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Hi i have a dell poweredge 2850. Orange LED blinking
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Jun 12, 2009 | Dell PowerEdge 2300 Server
Getting my scan from Rocoh aficio 1224c
Scanrouter will work just fine on a standalone PC- just set a static IP to make it more reliable. I've set up dozens of machines on single PC's and peer to peer groups.
It's very tricky to configure if you've not done it before, and it's getting a little difficult to find if you don't have a copy of it.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printronix P5412 Do not Print
Sounds like this unit has some electrical (minor) damage.
Sep 07, 2007 | Printronix PrintNet Print Server
ALERT LED light - Blinking Amber - Nothing prints, printer not recognized
The blinking amber light means there is a hardware problem. Got that from Netgear's website because we have a similar problem here. I don't know if it means hardware problem in the print server or in the printer. We put the print server on a UPS Uninterruptible Power Supply and that problem seems to be gone. We are in an old factory and the wiring is not so reliable. Maybe you could try this same fix.
Nov 28, 2006 | NetGear PS101 Mini Print Server Print...
D-Link DP 303 (DP-303) Print Server Logo
252 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
