Question about Fisher and Paykel GWL11 Top Load Washer
Fisher ad Paykel top loader plugged filter
I had a repair man here before and he cleaned the filter, but I cant remember how he showed me to do it, it was really simple, I don't even remember where it was.
  • Fisher and P... Master
  • 909 Answers
SUGGEST YOU CALL HIM AGAIN THEN TAKE NOTES
Posted on Aug 17, 2007
SOURCE:
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Tip
With only two fairly clean adults in the house, I use the front loading Kenmore...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl11 won't drain
This machine was made similar to a lighter.When it breaks you throw it away.
Jan 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Intuitive ECO Washer IWL16 Code 37
sounds like you've got something blocked in your pump. There's live wires under your machine near the pump so be very careful not to electrocute yourself. Best to get the repair man out and have him explain this time what's going on. I'd get a Fisher & Paykel authorized serviceman who knows what he's doing - call Fisher & Paykel with your zipcode and they'll give you some numbers to call.
Nov 19, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
