Question about Sanyo HT32744 32" TV
Sanyo DS31650 31
As a science and tech nut decided to take on the tv for learning experience.my problem and what i have done.. 1-typical power-on seconds later HV shutdown 2-replaced Horiz Out Transistor 3-it worked!,but, width became wavy and HV shutdown after 45 sec.Had trouble adjusting white balance. 4-replaced flyback transformer. improved white balance, still shutting down 5-voltage checks in multiple points on board seem to all be around 2x listed rating of said points. suggestions?????
  • 398 Answers
If the set runs at all, your flyback and output transistor are good. If the set shuts down after a few seconds and the sides are wavy, it usually means that the main B+ in your power supply is too high and not regulating properly. I do not know what kind of power supply that model uses, but if has an old-style STR regulator (like the STR30130) then it is probably shorted, and if the set uses a switching power supply then look for an open or leaky electrolytic cap on the primary side. If the power supply is working correctly and the set shuts down, check for an open safety cap (the large 1.6 - 2Kv cap connected to the collector of the horizontal output transistor).
Posted on Aug 18, 2007
May i know the qualification of each & every experts ???
Hi.
You can check our individual personal profiles and see what we state about ourselves.
To get to the personal profile type"http://www.fixya.com/users/(name of the expert here)".
Fixya counts thousands of experts and allows everybody to answer free questions. There are experts with no qualification at all and experts with long professional history and high level qualifications. Only selected experts can answer pay-for questions. In that case experts are usually qualified or they did build up technical background, skills and knowledge performing professional activity or DIY.
In my case:
Electronic Technician qualification.
Science and technology diploma (A Levels)
1 Year car garage experience.
Some plumbing and building experience.
Repair technician in a museum (4 years)
On Field service technician qualification.
Tech support qualification.
Electronic technician (over 10 years in shop and on field).
Car and motorbikes restoration (I still have 4 bikes ranging from 1932 to 1970).
Cisco CCNA 1.
Advanced network technician.
Engineering BSc Hon. (electromechanical engineer, appliance design, car electronics).
Teaching qualification (degree level)
Technology teacher (over 5 years).
University of Oxford-CLAIT - approved examination technician.
Engineering career.
Hobbies: learning, repairing, hunting, fishing, traveling, music....and Fixya.
All the best.
Ginko
Aug 31, 2011 | Health & Beauty
When u turn it on it has no picture or sound then there after it clicks on and off.
This is another typical issue with power supply boards. You need to have a qualified tech look at this and determine which board is bad, but it points to the power supply, they get the hottest and burn out the earliest.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
The tv turned off 4 times in 3 or 4 mintes and will not turn on now .
Sally, You or hubby or boyfriend will need to investigate the internal "switch-mode-power-supply" because it may be going into "shutdown mode" because it has detected a "fault condition" with itself or another periferal electronic circuit. If not into DIY repair, I suggest contracting out the repair work. Before you do that, a visit to YOUTUBE will help. Search out similar or same size Sanyo model there and here at fixya for any history of typical "black screen of death" symptoms that may be the same as your unit. After your research is done return to this posting and provide us tech's more info and what you intend to do about your sanyo unit. 12fixlouie
Sep 28, 2010 | Sanyo Televison & Video
I need the codes for a Sanyo tv
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 15, 2010 | Philips Magnavox Learning Universal Remote
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Will not turn on?
You problem is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist.
Jul 09, 2008 | Sanyo DP32746 32 in. LCD Television
Science
the small components insid ethe lap is produced with the help of modern science
Apr 09, 2008 | The Learning Company Achieve! Math &...
Original problem
You could have a power supply problem or a sweep supply problem. If you have had any TV repair experience, you will need to get a schematic and go from there. if you have not and still want to learn, Please read the article im posting for you. A tv set is not a place to be poking around in if your not sure where to poke. Good Luck http://www.techlore.com/article/15116/ Please do not forget to rate this thread.
Oct 23, 2006 | Sanyo DS27510 27" TV
Turn off 5-6 seconds after I turn on tv
Typical relay power problem on these sets for the relay power. most of the time, its the capacitor in the standby power supply that supplys the main 12 to 15 volts to the relay for the main power supply.. Problem is it is not a repair that can be done or understod by a layman in electronics. its a repair for an experienced tech as a TV set is not a place to be experimenting in.
Sep 10, 2006 | Philips TR2503C 25" TV
Sanyo HT32744 32" TV Logo
209 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
