Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
HP Pavilion DV9535nr -- problem
Hello... Im using Hp Pavlion Dv9535nr notebook.. I installed in XP servicepack 2 ... in SATA drive ethernet and nvidia geforce ... not supporting to sata nybody can tell me how can i install driver on SATA - XP
  • 2,961 Answers
When you first started the installation there would have been a pause in the set up offering you to press F6 and to install sata/scsi support using the driver supplied with the drive.
Posted on Aug 17, 2007
Dv9535nr graphics problem
if you are not getting proper graphic vision on your screen, its most probable that you need to replace the heatsink fan. Go to this link, select the issue you are experiencing . i hope this helps
please send me 4 thimbs up
Sep 18, 2011 | HP Pavilion dv9535nr Notebook
When i am installing windows xp on Hp pavlion dv3 laptop following error occurs "A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER IF THIS IS THE FIRST TIME...
Since, for your laptop you are downgrading the operating system from Vista to XP then with HP notebook.
You need to disable Native SATA support in BIOS utility and go ahead with the installation. To disable the SATA support you need to follow the below steps:
== Disable SATA native support:
1. Turn on or restart the notebook.
2. Press the F10 key when the "HP Invent / Compaq" logo appears on the screen. This will open the BIOS menu.
3. Select the "System Configuration" tab.
4. Select "Disabled" for the "SATA Native Support" item.
5. Press F10 to Save and Exit. Choose Yes for "Save configuration changes and exit now".
For more information on this visit the below link from HP.
Problems with SATA Drivers When Downgrading From Vista to XP
if you get any problem while doing this then plz get back. Actually you need to do lot of things to downgrade from Vista to XP on HP preloaded vista operating system.
Let me know if you find any difficulties doing this..
I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | HP Pavilion Dv3-1075us Notebook
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
XP on HP Pavilion dv2000
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:
Jan 24, 2009 | HP Pavilion dv2000t Notebook
i think you have a sata hard disk go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
Conexant High Definition(HD) audio :
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
Download the Ricoh 5-in-one Card Reader Driver from the link below :
Download Intel PRO/Wireless Drivers from the below weblink:
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
Realtek Ethernet Drivers :
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
Download the HP Quick Launch Buttons drives from the below weblink:
Download the HP Pavilion Webcam Driver from the below weblink:
Download the Alps Touchpad driver from the below weblink:
Finger Print Reader Driver :
Hope these helps...
Oct 03, 2008 | HP Pavilion dv2000t Notebook
HP Pavilion dv9535nr Doesn't work
you can mail to hp,plz check the hp wesite for more help
Jun 13, 2008 | Computers & Internet
Hard drive
My friend you need to be more specific in order to help you, what is the question?
Aug 30, 2007 | HP Pavilion dv9205us Notebook
Hi.... Problem in Sata drive
Hi ya have to get & Download from NVIDIA the NVIDIA SATA Drivers I believe.. here is a tutorial that helps ya with your problem..
Aug 17, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
304 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
