Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hi.... Problem in Sata drive
Hello... Im using Hp Pavlion Dv9535nr notebook.. I installed in XP servicepack 2 ... in SATA drive ethernet and nvidia geforce ... not supporting to sata nybody can tell me how can i install driver on SATA - XP
  • Anonymous Mar 22, 2014
    hi where to download mac os 10.5 and to install on pc sata hdd using usb drive thanks many times
  • Microsoft Master
  • 12,061 Answers
Hi ya have to get & Download from NVIDIA the NVIDIA SATA Drivers I believe.. here is a tutorial that helps ya with your problem.. http://www.cpusolutions.com/mm8004744CPU/HTML/Guides/Installing%20Windows%20XP%20on%20a%20SATA%20Harddrive.htm
Posted on Aug 17, 2007
SOURCE:
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
I can't format my HP Compaq 6720s Notebook,win xp say can not hdd drive ,but i'll get new hdd
The reason XP cannot detect the hard drive is because thr hard drive in this model HP is a SATA hard drive and the Windows XP installation CD does not have the SATA controllers on this CD.
To install XP on a SATA hard drive, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 03, 2011 | HP Compaq 6720s Notebook
When i am installing windows xp on Hp pavlion dv3 laptop following error occurs "A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER IF THIS IS THE FIRST TIME...
Since, for your laptop you are downgrading the operating system from Vista to XP then with HP notebook.
You need to disable Native SATA support in BIOS utility and go ahead with the installation. To disable the SATA support you need to follow the below steps:
== Disable SATA native support:
1. Turn on or restart the notebook.
2. Press the F10 key when the "HP Invent / Compaq" logo appears on the screen. This will open the BIOS menu.
3. Select the "System Configuration" tab.
4. Select "Disabled" for the "SATA Native Support" item.
5. Press F10 to Save and Exit. Choose Yes for "Save configuration changes and exit now".
For more information on this visit the below link from HP.
Problems with SATA Drivers When Downgrading From Vista to XP
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01675438&cc=us&lc=en&dlc=en
if you get any problem while doing this then plz get back. Actually you need to do lot of things to downgrade from Vista to XP on HP preloaded vista operating system.
Let me know if you find any difficulties doing this..
I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | HP Pavilion Dv3-1075us Notebook
Im using hp 530 and when trying to re install xp
you need to change native SATA settings in bios. then you can install windows xp. The steps are below
  1. Turn off the computer.
  2. Press the power button and press f10 to open the BIOS Setup.
  3. Use the cursor to navigate the Configuration options to locate the Native-SATA setting.
    • If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer
May 05, 2010 | HP 530 Notebook PC
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Xp professional installation on hp pavilion dv6700 cto notebook
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Mar 17, 2008 | Microsoft Windows XP Professional With...
HP Pavilion DV9535nr -- problem
When you first started the installation there would have been a pause in the set up offering you to press F6 and to install sata/scsi support using the driver supplied with the drive.
Aug 17, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
205 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
