Question about Sony Ericsson P990i Cellular Phone
Tuoch screen i have a problem with my p990 that my touch screen is not working properly only the boutom line is working
  • 5 more comments
  • oktbabs May 04, 2008
    roblem with keypad, touch screen. cannot use ok button after selecting bluetooth. Cannot use ok button after selecting 15 miutes for backlight.
  • Anonymous May 05, 2008
    i can't use touch screen
  • Anonymous May 12, 2008
  • eduj40 Oct 10, 2008
    i have the same problem. only the bottom line responds correctly. In fact if tapped anywhere on the screen it give the same response as the area on the bottom line exactly below it. Did a master reset, online upgrade, nothing worked. Wizard does not help as the key input does not function
  • Anonymous Dec 28, 2008
    My touch screen is not responding. Please help !
    My touch screen does not respond.
  • shah_birav Dec 31, 2008
    I cannot use my touch screen.plz help me.
I have a problem with my P990i that my touch screen is not working properly only the bottom line is working and when i touch the screen it always shows the network and button with text says flight mode.
Posted on May 12, 2008
Try to reconfigure your p990 interface by the setup wizard in the control pannel
Posted on Jun 09, 2008
U have to come out of the flight mode to normal mode,
Posted on Jun 07, 2008
SOURCE:
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How to unlock ipod tuoch
I believe that I have a very easy solution but let me warn you that this will cause a permanent loose of all the data you have on your device.
If you are ready then follow the tutorial posted here
Feb 14, 2010 | Apple iPod touch
I put games on my ipod tuoch but everytime i try to play a game it opens but closes right after
Yeah. This is a common issue, especially with these iPods. Firstly, try this: http://support.apple.com/kb/TS1702. If this doesn't fix the issue, try restoring the iPod(http://support.apple.com/kb/HT1339).
Jan 09, 2010 | Apple iPod touch
The tuoch screen does not work and after clicking once the navigation keys also gets stuck
Hey Sachin. Try to align the screen using Start> Settings> System> Screen> Align Screen. If this doesnot work, try doing a hardreset of your device
Jul 27, 2009 | Motorola Mobility ROKR E6 Smartphone
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
My p990i touch screen smashed
just try this one this may help you make your p990 as it simple form i mean just take your P990 FLIP(door)out. it can reset the touch screen hang(not worked) it has been exprienced with other p990 and it got solved.
Sep 19, 2007 | Sony Ericsson P990i Cellular Phone
Dell Ultrascan P990 19in CRT is getting dimmer
i had the same problem within a couple of days the monitor will stop working and it will start to beep....
Jan 30, 2007 | Dell UltraScan P990 19" CRT Monitor
Sony Ericsson P990i Cellular Phone Logo
915 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
