Question about JVC HR-S9500 S-VHS VCR
JVC AV-48WP55 Auto Index is always on how do i turn it off?
  • 979 Answers
Many models of this time frame have an auto index function, and will alway record the pulse when entering record mode from "stop" or "pause". To prevent this unit from recording the pulse, try backspacing the tape, then press "Play", then press "Record" while play is engaged. Always works for me. Another thing you can try if you want the machine to ignore the index on previously recorded material, is to switch the index function to "Counter"; When FF or REW, the unit will look for the counter "0000" rather than the index pulse. ...Accordianman
Posted on Oct 11, 2007
On my jvc tv 48wp55 i can not get the sound to come on please help
If its a setting, try turning
Center CH Input (located under Initial Setup) to OFF
Aug 22, 2014 | Televison & Video
No power on a jvc model 48wp55
must be the power supply or a fuse ,does the fan come on and a orange light beside the power light flick on and off?if so count the blinks before it shuts off could be the lamp program also,just refer to the manual that you can download freee from JVC M anuals and count the amount of orange flickers.
Apr 09, 2014 | JVC AV-48WP30 48" Rear Projection...
HOW TO FIX A JVC AV-48WP55 248W 48 INCHES BUT NO SOUND......? AT ALL SPEAKERS ARE GOOD
If speakers are not turned off in audio or main menu and not muted and not a box with the sound down---do you hear anything if put ear right to speaker?
Mar 22, 2012 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48wp55 Made a loud noise and went dead instantly.
WELL IF IT WAS A LOUD POP,YOU NEED TO REPLACE THE FLYBACK TRANSFORMER,GET THE MAKE AND MODEL # AND DATE OFF THE BACK OF TV, AND CALL MATS ELECTRONICS #1-800-628-1118
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
My JVC AV-48WP55 only blinks the green led when plugged in. This happened after a power surge, during a thunder storm.
Have you tried unplugging the tv and letting it sit for a while then plugging it back in?
also.. sometimes i have seen appliances that will flash the power light if an internal fuse has blown to indicate a problem. open it up if you feel you want to and check for a fuse around where the power cord comes in teh tv.
Nov 18, 2009 | JVC Televison & Video
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp55 shutting off on its own
Is pix ok before shutdown?
If convergence is wildly misaligned then load may be shutting down power supply. Fix convergence and TV OK.
or
Poor solder connections on main chassis near FBTX and h drive. Needs expert solder work
easyab@hotmail.com
calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 14, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp55
Replace the IC power STR.s6709 and
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc television want come on
Reset is done by unplugging the ac cord for a time,then plug
back in...............Please verify model number off sticker on the
                            rear of your tv...let me know.....T.
Oct 22, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC HR-S9500 S-VHS VCR Logo
78 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
