Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Display drivers showing big icons and unable to set the display
  • pinkrain Mar 13, 2008
    display big icons. Can't be corrected in display section from control panel.
    Scholar:
  • 173 Answers
Look in control panel , system, hardware,device manager. see any yellow question marks? remove all of them, reboot and windows will find your hardware again the display driver cd it will ask for it. or if lucky pick it from a list.
Posted on Aug 17, 2007
Display issue
Good day!
go to display settings then click on monitor tab change graphic monitor to Generic PnP monitor or the installed VGA driver on your computer.
Mar 28, 2014 | ASUS X55C-XH31 15.6" Laptop
Dark screen
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 21, 2012 | Toshiba Satellite E105-S1402 Notebook
Unable to install on screen display after windows 7 installation
What do you mean unable to install on screen display? Are you saying your screen is blank?
Maybe you need to reinstall the video drivers.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If you are saying that the system boots up and everything seems to be running except the screen is blank then try the steps below.
May 14, 2012 | IBM LENOVO - ThinkPad R500 - Genuine...
Unable to load on screen display on lenovo r500
May 14, 2012 | IBM LENOVO ThinkPad R500 - Genuine Windows...
My screen show big icon...wht problem??
Hi, This is the problem of screen resolution. First check that you have installed the display driver properly. Reset the resolution best compatible with your system and monitor. You can reset the resolution in standard 1024*768 pixel.
Oct 18, 2011 | Computers & Internet
The icones om my iphone 4 are big and some of them are outside the screen
Hi..!
try to check whether display settings in ur phone are changed?
whether if u are unable to correct try to set default display settings!
by using phone menu..!
cheers......!
Feb 14, 2011 | Cell Phones
I am unable to connect to the net for about a month now I also notice that there is a yellow symbol infront of the Internet signal
This indicates that there is limited or no connectivity.
Here are a few things to try out.
first is to check that you network drivers are in shape.
  1. click on the windows start menu and click on run or press the windows logo key+ r
  2. type "devmgmt.msc" without the quote in the run box and press enter/ok. from the windows that appears make sure that the network adapter filled is not showing and yellow symbol. If it does then you need to install new drivers for the network.
  3. If no yellow symbol is showing then looks like your internet settings needs configuration.
For configuration
I will be very glad to help more but i will be limited to how far i can go. the only issue here is where you use a local area network or a form of wireless connection.
Anyway you need to perform manual configuration to have connections but in just a few cases this does not help much, most is based on the drivers installed correctly and a little from the ISP.
Now here is what i want you to do for me.
Double click on that the network icon if it is showing on the taskbar.
1. If it is not showing .......go to my network places.
2. click on "view network connections" on the left pane
3. right click on the network icon from there the displayed result and choose properties for the list
4. From the displayed properties make sure the two boxes are all checked/marked and click ok when done.
Now you should have the netork icon displayed. click it.
1. click on "support" from the tab
2. Write down the information showing on that panel
3. Click on "Details" and write down that information as well.
Send them to me so i can give you the required setting to get your connections working.
Dec 05, 2010 | HP Computers & Internet
Screen icons and picture too big
What is the OS??
Right click on the desktop and click on "Properties", "seettings" and set screen resolution to at least 1024 X 768 for LCD monitor or 800 X 600 for CRT monitors.
If they are set to those then there may be a prob with video driver.
Need more in depth explaination.
Dec 21, 2009 | Dell OptiPlex 170L PC Desktop
Nokia 6085 - unable to clear headset icon on display
i fixed this problem
The phone came with a headset. Plug the headset in and out a few times; it should reset the headset icon and phone can be used regularly again
Mar 21, 2008 | Cell Phones
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
