Question about IBM Infoprint 1332 Laser Printer
Maintenance shedule error
I've install maintenance kit for ibm infro 1332 printer but still coming up with maintenace shedule on the control panel How do i reset maintence error??????????
    Scholar:
  • 31 Answers
Power off the printer and hold down the two top right buttons and power the printer back up. You will be taken to a menu that you will be able to scroll through. Look for the "Maint Count Reset" option and press the "enter or go" button and reset the count.
Posted on Aug 17, 2007
SOURCE:
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
We changed the fuser on the IBM Infoprint 40 Model #004, Type 4332. However, after changing the fuser, we still get an error code in the display that says "008 Change Fuser." What does code 008 mean? ...
008 is the printers code to tell you to replace the Maintenance Kit. IBM Part Number 90H3567. After installing it, you have to make sure to tell the printer to reset the count value for that maintenance kit.
Jun 11, 2010 | IBM Office Equipment & Supplies
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Xerox Phaser 8550 Maintenace Kit is stuck in the
If you remove the right side cover, you can operate the process drive gearbox with a straight-blade screwdriver on the end of the shaft (bottom of printer right in front of maintenance kit). This is the end of the drum maintenance camshaft. Rotate clockwise slowly. It's possible that the cams have cracked and rotated on the shaft. This is the weak point on these printers. If so, they may not be in sync. Good luck.
Jul 13, 2009 | Xerox Phaser 8550DP Printer
Error 80-maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
[email protected]
Jul 07, 2009 | IBM Infoprint 1352 Laser Printer
I am getting paper jam error code 201 and it has been happening more often the last couple of days. Would this indicate I need to install maintenance kit??
It can indicate you need pickup rolllers. You can confirm this by checking the rollers in each tray. If they feel smooth, then they need to be replaced. These do come as part of a maintenance kit, but the full kit cost a couple hundred dollars, while the rollers cost under 10. If it is not prompting you for a kit, only buy the rollers.
Jun 24, 2009 | IBM Infoprint 1332 Laser Printer
Keep getting an error message "202 Paper Jam Open Rear Door", cannot clear the message. We ordered a maintenace kit maybe 3 months ago.
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Apr 20, 2009 | IBM Infoprint 1352 Laser Printer
Maint kit install and page count
Pretty easy, the maintenance kit consists of a transfer roller (black roller that sits underneath toner cartridge), charge roller (sits above toner cartridge), fuser (rear of printer behind two plastic covers), and paper feed rollers. The maintenance kit should have details with diagrams.
To reset
To reset the Maintenance counter, turn off the printer.
Press and hold both Select & Return while powering on the printer.
Hold until display reads 'Performing Self Test" then let go of the buttons.
If the printer displays "80 Maintenance Due" Press the Go Key.
Press the right Menu Key and scroll to Reset Maintenance Counter.
Press the Select Key. Press the Select Key again to reset the counter.
When the reset operation is complete, press the right Menu key to exit Configuration Menu and press Select.
Printer will save the settings, IPL and come back to Ready.
Oct 30, 2008 | IBM 4528-n01 Printer
Maintenance error 80
Put a maintenance kit in the printer and then reset the maintenance count.
Dec 07, 2007 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
804 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
