Question about GE 25GT240 25" TV
Pictureis very bright
The picture is very bright but i can still see color in it and from time to time it blinks with a white line in the middle of the screen then it goes back to normal i had it in my shed and i think it got wet a little bit but if any one can help me feel free to respond
  • 3 Answers
With the brightness problem, first have you tried adjust the brightness on the menu. if not try to adjust it first if nothing happens set it in the middle. and if you are confident enough to fix the tv while the power is turned ON, 1.first open the back panel or back casing to expose its components turn it OFF first before opening it, 2. next if you have the schematic diagram of the (PCB) Printed Cuircuit Board find the variable resistor (VR) for brightness. if you dont have the schematics for the TV, try to find it on the PCB its a flat piece of metal that has 3 terminals and a rounded face that can be turned to increace or reduce resistance. it is mounted standing up. usually it is beside another VR for the horizontal control. it is labeled as brightness on the PCB surface. 3. when you have found it plug in and turn the TV ON tune it on the clearest channel that you can find, 4. and then using a non-metallic screw diver turn the resistance plate that would be the face of the VR first slightly turn it to the left then check the monitor for results you can place a mirror in front of the TV so you can check while adjusting the VR. just make slight turns on the VR Left to Right until picture is clear. **remember to use a non-metallic material to turn the VR to avoid elctricution. With the with white line problem or i usual call it the Stick. there is already a problem with some components on the vertical section on the PCB. it would be any of this parts the Capacitor, resistors, trancistors, and i would suggest that for you to have it checked by a technician coz it would be hard to determine which parts is faulty.
Posted on Oct 08, 2007
SOURCE:
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
I have blue arched lines on my sony kp 57wv600 is there a fix for this
Those are retrace lines, the screen controls which are a technical control located under the front gray panel of your tv needs adjusted. This also could be an indication of a bigger problem, most common would be the focus block failing. it could also be of the picture tubes failing but this is not as common or possibly the crt driver ic's. There are specific diagnositc steps to preform to isolate the potental failure. this could lead to the tv going very bright then shutting down.
The first thing a tech is going to do is to adjust the screens and leave, somtimes this is enough, but sometimes it is not. if you want to try and adjust the screen i have an instruction set below, but i must warn you that there are high voltages present when attempting this adjustment and can be dangerous if you are un familure with tv repair.
Turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Aug 05, 2009 | Sony KP-57WV600 57" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Yellow Scanning--Trying to scan a color picture
first thing is to make sure the glass and the white backing on the lid is VERY clean.
then go to this link to trouble shoot --
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=2512008&lang=en&
Dec 25, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
No Picture Has a bright horizontal line with off white & gray vertical bars
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
HTTP://WWW.servicemanuals.net/results.aspx?type=SM&brand=100&model=27ts54
I request any info or tips you might have pertaining to this problem
Thank-you
Sincerely
Gmyers@sbcglobal.net
2/20/2008
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
NOTE
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Dec 31, 2007 | Samsung TXK2754 27" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Sony wega 36" blinking problem
Yes this sounds about right for a set this age.
May 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
GE 25GT240 25" TV Logo
50 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
