Question about Philips 170S4FB 17" LCD Monitor
Monitor only stays on for 3 seconds
Screen only shows a picture for about 3 seconds then blank black screen, power switch on and not flashing. If i turn screen off then back on again shows picture for 3 seconds and again changes to a blank black screen. Have tried another power source and another computer with the same results.
  • Anonymous Mar 28, 2014
    screen goes blank but power switch is till on, if I switch it off and back on it clears for about 5 seconds then goes blank again
  • 63 Answers
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Posted on Aug 17, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
Replace the CCFL lamps located in the LCD panel.Bad lamps may still light up, but draw excessive current, causing unit to shut down.
Posted on Dec 01, 2011
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Philips 170S4FB 17" LCD Monitor Logo
683 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
