Question about Maytag Chassis Built-In Air Conditioner M7X05F2A
My AC doesn't blow air Why?
It just makes sounds
  • Anonymous Jun 07, 2008
    TURNS ON RUNS FOR 5 SECONDS AND THEN SHUT OFF
  • 50 Answers
It may need cleaned, or the blower motor is out. First check the evap coil to see if it is dirty.
Posted on Aug 18, 2007
2 Suggested Answers
  • 387 Answers
SOURCE: The air conditioner stopped blowing
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Posted on Jul 19, 2011
2014 Chevy Texas addition changed battery now ac doesn’t work only blows hot air
Did you blow a fuse to the AC compressor? Are you low on freon?
Jul 17, 2018 | AC Cars & Trucks
04 Santa Fe burning smell running ac....
Sounds like the A/C compressor clutch has overheated and become inoperable. Open the hood, start engine, observe the compressor face. It should be turning and also see if that's where the noise and burning smell is coming from.
Good luck!!!
May 16, 2013 | 2004 Hyundai Santa Fe
My ac wont turn off and only blows at one speed
faulty resistor won't make it blow warm air.
sounds like the climate control is bad.
Sep 04, 2012 | 2003 Honda Accord
2005 altima blowing hot air
could be your switch, or you have a freon leak and there is no freon in the system. open hood and watch the ac pump and have them turn on and off the ac. if in engages then it is probably freon. if it doesn't check ac fuses.
May 26, 2012 | 2005 Nissan Altima 2.5
The ac on my Isuzu box truck doesn't work it blows
where is the low side fitting on a 2005 isuzu box truck i need to charge ac
May 12, 2012 | 2007 Isuzu MU-7
98 VW Beetle AC acting up I have a 98 VW Beetle
without putting my machine on it and extracting the gas to see how much gas their is by weight then i couldnt even think of a reason for this sorry
Sep 13, 2011 | 1998 Volkswagen Beetle
I have numerous proglems. I have a 2000 intrique. The right back signal light blinks very fast, doesn't work in the front. The ac blower works fine but blows warm air.A mechanic , someone my hysband...
Your rear turn signal flashes fast because the front is not working. Most likely you have a burnt out bulb in the front. If your A/C compressor can be turned over by hand and doesn't lock up or make any clanking sounds it's probably alright. The compressor will not run if the system is low on refrigerant. If you're having problems with the A/C and heater controls, that would be the first ting to repair. It doesn't sound at all like any electrical problems.
Jul 20, 2011 | 2000 Oldsmobile Intrigue
I have an LG window air conditioner that's about 2-3 years old. The cooling function doesn't work. It just blows air and makes the air conditioning sound. How can I fix it? Is there a cheap...
Hello, this could be a problem with the thermostat on you ac and not turning on your compressor or the unit has no revrigerant in it. Here is a links to where you can buy window ac's online. http://www.amazon.com/Frigidaire-FAX052P7A-Window-Unit-Conditioner/dp/B000Q7GSHQ. You can also try sears they might be able to install a window ac for you.
May 13, 2011 | Heating & Cooling
The air conditioning isn't blowing cold air anymore. It takes a while for it to get Cold, it blows cool air but not cold.
My name is Ron,and I have one solution,Sounds like you need some freon added,if that doesn`t fix ya ,the ac compressor could be weak,or blockage in ac system,or vent door not opening,or opening slowly,and not all the way...hope this helps,roniecon@gmail.com
Jul 19, 2009 | 1996 Ford Explorer
Maytag Chassis Built-In Air Conditioner M7X05F2A Logo
123 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
