SOURCE: dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
SOURCE: power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
SOURCE: wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
SOURCE: dell latitude d610 not charging battery
See the Adoptor status in the bios, if it is not detecting it the adoptor fault otherwise you have mentioned above you have already replaced the battery then it is m/b issue
