Cuisinart Cwc-800 Private Reserve Wine Cellar Logo
Anonymous Posted on May 31, 2013
Cuisinart repair I need four transistor # D13005MD or the all power card.thank
Output transistor for Onkyo TX SR574
Hello, sorry, we do not sell repair parts to end users. Only authorized repair centers. Thank you, Onkyo USA
2answers
Power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
1helpful
I haves an amplifier SONY TA-F210 to repair. The four "final" transistors are take out and miss. I haves no ideas of witch kind of transistors need. Please I need the list of component (or the...
You can download the manual included schematic diagram from here:
http://elektrotanya.com/sony_ta-f110,f210.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading.
Thanks.
gylacz
2answers
I received a PV1500 amp that had only one channel working. i decided to open the amps to check the other channel being that i usually repairs amps. up on analyzing the damage circuit board of that channel,...
It seems there's another component (a capacitor, a diode, etc) causing a short circuit to triac and transistor, or there's an over voltage on this stage, please check if the voltage is according to the one feeding the good channel.
2answers
The cooler just turned off, no lights, doe not work, plugged it into a different outlet, still nothing I had it inside a cabinet if that makes any difference, but it did not eem to be overheated
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
Can not turn the machine on -need electronic card
Hello fmenou,
Cuisinart will not sell parts except to small appliance repair parts. I would caution you to consider whether this would be safe to use even if you could replace the card. :o) Kind Regards, NormanZ
Please help me fix this benq monitor
There are many posts that have solved this. Check em out
Tv repair
you can try to check if the problem is near flyback transformer
you ha to disconnect the power cord , open tv and locate power
transistor for generate high voltage it is near the big four connector
cable the transistore you have to dissolder from board and check
with multimeter if it is shorted or not in this way base to collector
junction about 500 or more base emitter the same  collector to emittor open - delfo
4helpful
6answers
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Top Cuisinart Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
