Question about Motorola Mobility HS820 Consumer Headset
Mic doesn't work
No one can hear me unless I take the unit off my ear and right against my lips.That's the only way others can hear my voice but as you might have guessed it,this is not very practical since then I won't be able to hear anyone,LOL.
    Scholar:
  • 130 Answers
Is anything blocking the mic? Maybe there's a sensitivity setting on the headset or the phone? I'd recommend connecting it to a Bluetooth Enabled PC and try recording with sound recorder to test the sound quality/volume. If it's ok on the computer, it's a problem with your phone. If it's still quiet on the computer, I'd recommend you send the headset away for repairs/replacement of defective device.
Posted on Aug 17, 2007
SOURCE:
When I hold my new iPhone 5 with my left hand, the caller says my voice is muffled. Not so if holding phone on right side.
This is because the mic is located on the left side (phone facing toward you) as you switch hands the mic is moved further from your mouth.
Dec 22, 2012 | Apple iPhone 5
Turned up full volume u can only just hear sound if ear right to it was working fine then the volume just ******** out
It could be the mic plug. uniden is known for the issue where the wires inside the mix plug break at the solder joints.
When the RX wire breaks, you will loose receive because the radio will not go into receive mode. But you can usually hear it ever so slightly if you crank the volume.
Other issue that may cause this. No radio activity, (unless you hear radio activity low and not static)
poor feed line or antenna.
I would try a different mic that is known to work.
Aug 11, 2012 | Radio Communications
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
How do i turn up the speaker volume not the ear piece volum but the "speaker" volume people say they can't hear me
you probally have a bad internal mic. on your phone most phone models that i have worked with dont have a volume control for the mic.
May 23, 2011 | Cell Phones
2600: speaker is ok but no sound in nokia2600...
Change your earpiece.Need to know in phone have 3 kind of mic:1,microphone to make somebody hear our voice. 2.Ear piece to make we can hear for sombody voice. 3..Buzer to make phone ringing or louder sound when somebody speak (speaker). in that case your earpiece is not work,so change your ear pice. I hope it help.
May 17, 2010 | Nokia 2600
When i talk people cant hear me though turtle
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help -- [email protected]
Mar 04, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Turtle Beach Ear Force X1 Mic not working
Can other players hear you speaking on XBOX Live chat? I'm not sure if you mean "you" can't hear yourself speaking or that "others" can't hear you speaking.
Dec 26, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Mic wont work, i can hear friends but they cant hear me.
Can you try using the X1 mic on your PC? Green plug to green jack, pink plug to pink jack, USB plug to USB port. Talk into the X1 mic. Can you hear your voice? If yes, then you probably have a bad chat-controller cable. If no, then your X1 mic may not be working. If that's the problem, you should contact Turtle Beach tech support for help. [email protected]
Dec 24, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
My micriphone attached to headphone seems not to work.
First, make certain that the mic is really broken, by testing it in another application or devise. Sometimes you cannot hear your own voice unless you are in recording mode! If the mic is found to be working, then try to reconfigure the software, or the Yahoo connection. Good Luck!
Dec 06, 2008 | ASUS Computers & Internet
Headset mic doesn't work
Disconnect the all lines and power
Remove battery of the headset
Put battery back in
Connect phone line
Connect power cord
I am trying this according to Thomas 800-511-3180
Jan 16, 2008 | RCA 25110RE3 Phone
Motorola Mobility HS820 Consumer Headset Logo
75 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
