Question about Maytag Neptune FAV6800AW Top Load Washer
OP Code Machine is stuck with a code of OP. The manual says that the door is open. I'm not the smartest guy out there but I closed the door and the code won't go away. I unplugged it for a few minutes with no luck. Switched the breaker and nothing. Stop or trying to clear the code doesn't work. The wife is pissed because my parents were the last to use the washer.
  • 1 more comment
  • Anonymous Nov 17, 2007
    where is the door switch located i took top off but didnt find any broken wires thanks
  • chapped Nov 29, 2007
    my washer code says OP on the display but my door is not open and the stupid thing wont start up and my laundry pile gets bigger the thing that urps me is I paid nearly 1000 dollars for this pile of bolts
  • Anonymous Jan 03, 2009
    how do you pop the lid?
The problem was the lid switch. Popped the top and opened the wire harness. Black wire had snapped due to corrosion. Re-soldered the wires and closed (& sealed) the assembly. Thank you for your help.
Posted on Sep 11, 2007
  • Maytag Master
  • 909 Answers
ONLY O9NE QUICK SOLUTION. UNPLUG THE WASHER THEN LOCATE THE 2 WIRES CONNECTED TO THE DOOR LIMIT SWITCH. BRIDGE THEM OUT CAREFULLY THEN PLUG WASHER BACK ON AND TRY. IF IT CONTINUES, CALL A TECH AS BOARD COULD BE AN ISSUE.
Posted on Aug 17, 2007
Troubleshooting manual washer code op door locked wont open unplugging didnt work
You can release the washer top from the base with a putty knife
See page 33 of the FAV6800A/FAV9800A Service Manual
Your machine is a FAV6800A or FAV9800A correct? If so you have Left Hand Lid Lock signaling issues to the Control Board.....are you the DIY type of owner? If so I will help you to issue resolution.
Rich
Jul 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Op code with the lid closed
Greg,
You have lost signaling thru the Left Hand Lid Lock.
See this link for OD troubleshooting. If you have questions post back and I will help you….Rich
Some handy links for your machine FAV6800A or FAV9800A correct?
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Dishwasher latch handle is stuck in closed position. The door will not open. How do we get it opened?
I had the same problem and with some pushing and pulling I got the door open again.
TURN OFF THE BREAKER....
Next take all the screws out of the door panel to access the door latch assembly. You will see the handle has plastic tabs that hold it in place which are broken. Order a new assembly and install it.
My problem was getting the wiring harness off of the switches they are clipped on very tightly so I just kept the old ones connected and put them on the new assembly.
Good luck
O
Jul 11, 2009 | Maytag Dishwashers
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
Jun 10, 2009 | Haier ESD400 Stainless Steel 24 in....
Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Mar 12, 2008 | Office Equipment & Supplies
How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
power down copier at op-panel.straightend end of paper clip into little hole by op-panel power button.hold in till little dot appears on screen in middle to the left.press #3.that should get you to trouble reset.Or sometimes opening and closing rightside door can reset.
Dec 01, 2007 | Konica Minolta DiALTA Di200 Copier
Maytag Neptune FAV6800AW Top Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
