Question about Cyberhome DVR 1600 DVD Recorder
Disk error I have a problem after I set the recorder to copy something it does but then after its done recording and I'm trying to edit it a "disk error " shows up. I have recorded things in the past with no problems any idea what the problem might be.
  • 67 Answers
Clean the lens using coton and water
Posted on Sep 16, 2007
I'm trying to copy a tv show from my DVR and the recorder keeps saying Recording Error This program is not recordable in +vr mode. What is +vr mode?
Recording mode is set wrong, change it and try again unless there is an anti-copy signal on recording which some money hungry cable companies do to screw with customers.
Sep 01, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
Editing DVD RW disks
What soft did you use?
Mar 01, 2008 | Televison & Video
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
Not able to record movies/shows from cable box onto dvd recorder
Sorry I can't answer directly but just wanted to suggest you bought a PVR or personal video recorder that uses a computer-type hard drive.
These devices are a lot less hassle when only short-term storage is needed and any content you want to keep can be recorded later onto hard copy. I still prefer vhs for that as it is possible to edit tapes or cut out bad portions if something goes wrong - not something easy to do if a cd or dvd gets damaged.
Mar 24, 2017 | JVC DR-MV7 DVD Recorder/VCR
Dubbing vhs to dvd
If you try and record a video with copygaurd it will only record a tiny section. If you press stop or return for 3 seconds you will cancel the recording, try pressing the pause button you edit out adverts, i have not tried this yet but it might work.
Dec 31, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copy Protection Signal
"Copy Protected Signal." Means that the data you are trying to Ahem... "Copy" probably has copy protection inbuilt into the disk & data. This is done to stop copying of pirate DVD's etc. Part of the DRM put out by the TV/Music/Film industry. There are programs that can strip protection and enable one to copy said DVD's.. AnyDVD is one that springs to mind, as does Dameon Tools, and many others simply Google for them.
Jul 11, 2007 | Panasonic DMRES15 DVD Recorder
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Cyberhome DVR 1600 DVD Recorder Logo
65 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
