Home | TurboChef | TORNADO Electric Oven | My turbo chef owen sen...
TurboChef TORNADO Electric Oven
Problem for TurboChef TORNADO Electric Oven
My turbo chef owen sense somtime 208vac and some time 240vac
By ajp1111 on Mar 21, 2009
oven works fine when it sense 240vac but once its got heated and after 4 hours it senses the 208 vac and its timer is not working
Same Problem
Apr 07, 2009
-   208vac and some time F6 ec temp call service eng
f6
f620 -   Guest
Solution #1
posted on Apr 11, 2009
Not Rated)
jriceskin
Rank: Guru
Rating: 94%, 47 votes
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Hope that helps, and thank you.
Was this helpful?
Yes
No
Popular Solutions for TurboChef TORNADO Electric
Questions and Unsolved Problems for TurboChef TORNADO Electric
Do you recommend TurboChef TORNADO Electric Oven?
Answer
Answer
f1 blower fault comes on after a few seconds of warming
Answer
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and ... (More)
Answer
I have both a tornado and a C3. I am getting a F2 low temp reading on one and a low mag reading on... (More)
Answer
Its Cummins Technologies India Ltd. Can a company have more than one TAN number in the same city?
Answer
I have a Kenmore stove with a self clean oven. I cannot find the switch to turn off the oven light.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For TurboChef TORNADO Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
