Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore direct drive will no longer self-propell
My Kenmore Progressive Direct Drive vacuum will no longer self-propell while vacuuming the carpet. The suction works and the brushes rotate. How do I get the vacuum to self-propell itself again?
  • Lakelife Jan 05, 2008
    My Kenmore will no longer self propel and it doesn't vacuum as well because of it. My vacuum is only 3 years old. This is ridiculous
  • brijamgel Mar 07, 2009
    My problem sounds very similar, if not the same.
    Mine won't self-propel, unless the handle is lowered to a ridiculous angle (unless you happen to be very short). When you lower the handle though, it lifts the agitator/brush off the floor surface so it is useless anyway. I can turn the agitator off and on by lifting and lowering the handle- there is a precise point where it stops. The reset button has not popped up.
    It is about 2 years old. Anyone know what part could be failing to cause this?
    Model# 11636923502, Progressive, Upright, Bagless/Beltless
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Posted on Feb 13, 2008
    President:
  • 1,673 Answers
Most self propelled vacuums have a cable running from the handle down to the drive mech. It may have broken.
Posted on Jan 05, 2008
SOURCE:
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Direct Drive System on Kenmore 31913 Vacuum
you need to reset it on the front. overload reset button
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Self Propel
Determine if the wheels spin freely or if there is resistance. Sounds like you need a replacement belt for the drive. If you need help with installation, let me know.
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
919 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
