Question about HP PSC 500 All-In-One Printer
Cartridge The tape/belt that pulls the ink cartridge broke.can i fix it?
  • 661 Answers
You need a replacement belt as any repairs to the belt will not withstand use, you may be able to order this part online
Posted on Aug 17, 2007
To install new ink no instructions about what to remove before installing?
You pull off the tape that keeps the ink form leaking before you install the cartridge or it will not print.
Jan 16, 2016 | HP No 61 Black Ink Cartridge
Ink cartridge broke
If you can still print with it, try taping over the crack with tape (I'd try electrical). No guarantees though but it should add some life back. If the broken section is near or at the jet area, I'd replace it.
Apr 30, 2014 | Evolis Zenius Expert Single-sided Card...
Seal tape from toner cartridge tore
prining invoices to letterhead, your laser printer is an integral part of your company's computer system. The device's ink is stored in one or more toner cartridges that are replaceable - a single black cartridge, if you have a laser printer that only prints black, or three color cartridges along with a black cartridge if the laser printer prints both color and black. The cartridges are available at office supply, retail and warehouse stores. Like inkjet cartridges, toner cartridges contain a strip of sealing tape that keeps the powder ink from spilling out until you are ready to install the cartridge.
Sponsored Link
Computer AMC ServicesOnlinepcshop.in
Laptop-PC Repairs in Delhi NCR. Total PC Solutions. Get Free Quotes
1Remove the toner cartridge from its packaging, if the cartridge is still in its box, and shake the cartridge from side to side to evenly distribute its toner.
2Hold the cartridge away from your body so ink won't spill onto your clothes or shoes. Grab the cartridge's sealing tape on the side of the cartridge and pull the tape firmly away from the cartridge. The sealing tape contains a plastic end piece for grasping it, usually in a different color than the toner cartridge.
3Continue pulling the sealing tape until it is completely out of the cartridge. Place the cartridge close to your printer or on a surface nearby until you are ready to install it. Dispose of the sealing tape in a trashcan or bag; try not to get any toner present on the tape on your hands or clothing.
Sep 14, 2013 | Xerox WorkCentre 4150 Black and White...
New ink cartridge load test run prints lines on paper then tells me to take tape off cartridge which i've already done ???????
1. I would shut the printer down and pull the cartridge back out.
2. Find a Number 2 pencil with a good eraser on it.
3. Pull the Ink Cartridge back out, and use the pencil eraser to clean off all of the copper contacts that are behind the cartridge.
4. Replace the cartridge, and run a head clean process.
5. Align the heads and test the printing.
That should fix your issue.
Aug 29, 2011 | Lexmark Office Equipment & Supplies
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
The ink cartridge holder plastic lock broke where the top of the holder clicks into the bottom to hold the ink cartridge in place. what can i do to fix it.. tape doesn't hold
If you have the quick fix --
S
elleys Quick Fix GelFast setting ethyl cyanoacrylate (supa glue) based adhesive with a non-drip gel consistency which dries clear.
What materials is this product suitable for?
  • Bonds a variety of porous and non-porous surfaces
  • Metals
  • Wood
  • China
  • Rubber
  • Leather (test first as some leather may become hardened or discoloured)
  • Some plastics
I or have to purchase the part
Jan 04, 2010 | Lexmark X1150 All-In-One InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
CANT FAX
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  8. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  9. Fold the scanning unit support and close the scanning unit (printer cover).
  10. Wait until the preparatory operation is complete; it takes about one to two minutes.
Mar 28, 2008 | Canon MX300 Office All-In-One Printer
Scanner
Solution: Replace ink cartridge(s) MX310.
Feb 08, 2008 | Canon MX300 Office All-In-One Printer
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
