I get no image on the screen when I turn the camera on. If I take out the memory card I can view internal memory pictures but cannot see images on the screen to take pics and cannot see pics on the card.
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen. Read the following steps once and make sure you understand before action.
(1) Load your camera with a freashly recharged battery. (2) Switch on to see if it's working and still without the real time screen. (3) Switch it off, and hold it tight in you palm with the LCD facing inward. (4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash. (5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear. (6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it to your elbow. (7) When you are ready, try first not to hit your elbow too hard once. (8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are
saved by default to the camera's internal memory, which holds different
amounts of images based on how many megapixels are built into the
internal memory and what image quality and compression are selected in
the camera's menu. Once a memory\picture card is inserted in the camera,
the camera then saves the photos to the memory\picture card and ignores
the internal memory.
There are two ways to transfer the images from the internal memory.
To transfer photos to a computer from the internal memory using the
USB cable, first remove the memory card from the camera. Then, when the
camera is connected, the computer and software will only see what is in
the internal memory and transfer those photos or videos. During the
transfer process, the computer makes copies of the photos and videos-the
original images remain in the internal memory. After the transfer is
complete and the camera is safely disconnected from the computer, the
contents of the internal memory can be deleted by using the MEMORY
FORMAT function in the SETUP menu in the camera's menus.
The other way to transfer photos from the internal memory is to
transfer them to the memory\picture card using the BACKUP function in
the SETUP menu. If there is no memory\picture card in the camera, the
BACKUP function is grayed-out. During BACKUP, copies of the images are
transferred to the memory\picture card-the original images remain in the
internal memory. After the BACKUP is complete, the internal memory can
be cleared by removing the memory\picture card and formatting the
internal memory using the MEMORY FORMAT function in the SETUP menu in
the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Can you power up the camera don't take a picture but move around the functions and view pictures on the LCD screen? If the camera does all the functions it's suppose to except hold a picture then I'd say the memory is at question. You might not have a memory card installed in the camera and it's working on the Internal Memory which is now full or not able to load another picture. If there is a memory card in the camera it might have the protection switch in the lock position which then would shift the picture storage to the internal memory. You need to check to see if there is a memory card in the camera if so make sure this card is in the unlock position. If the images are on the internal memory then you need to transfer the internal memory pictures to the memory card for download to the PC. Make sure the memory card is unlocked and formatted to the camera after you download the pictures to the PC
Your memory card or internal memory may be full. I've run into situations where the card full doesn't flash on the monitor or LCD screen because there is lets say 3 gigs of memory left but the picture you are taking is 3.5gig's it won't take the picture because there isn't enough memory to put the image anywhere. Download your pictures to your computer, format your memory card and all should be good again. If you are using the internal memory you will need to obtain (buy) a memory card for your camera and download from the internal memory each picture from the memory card one by one until all the internal pictures are on the removable memory card then download these to the computer. After you have them on the computer go back into the internal memory and delete each of thse pictures and you are ready to start taking pictures once again. it took me longer to type this then the process will take to do.
-Turn On camera -press Menu and go to setup -Under setup look for Choose image storage and switch to internal Memory -Now if your image storage set into Internal memory, Press menu again to exit menu settings -Press review button for you to able to see picture from internal Memory -now Press menu again while viewing the slected picture that you want to transffer -It will provide option PICTURE/ALL/EXIT -If you want to transffer all the picture select all -If you want to trnasffer selected picture select picture.
Note: You need to set your Image storage into AUTO so you can use your memory card to take and view picture
No this camera does not have any internal memory. All images should be written to the memory card if the memory card is inserted properly. If the memory card is not inserted correctly the camera screen will show a message of No card. Do you see that message?
Push the options/settings button (the button next to the view/playback button)
On the Capture Screen move over to "Setup"
Move down to "Image Storage" and make sure its set to "Auto" {if not select it and set it to Auto}
If already set to Auto, change to Internal Memory.
Power off and power back on then follow steps 1-4 to set back to Auto.
If this still doesn't work, backup pictures from internal memory to computer then delete all pictures on internal memery. Camera should automatically prompt you to change to memory card.
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera - Turn on camera - View pictures on the internal memory by just pressing on the PLAY mode button
(lowest of the 3 little buttons) - Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera - Turn on camera - View pictures on the internal memory by just pressing on the PLAY mode button (
lowest of the 3 little buttons) - Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera - Turn on camera - Press on PLAY mode button to view pictures - Press MENU/OK button - Keep scrolling to the right until you see COPY TO CARD - Select YES using the arrow keys - Press MENU/OK to confirm * When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset the FILE NAME settings to 100-001.
when you view pics it is best to download them to a temp file
if you don't want them easy to delete.
once the cam views them they clear the memory.
clear simple process without paying gateway about 80 buck's
The internal memory and the xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
