Question about Kenmore 22422 Top Load Washer
Will not drain
My washer will stop at the rinse cycle and will not drain to spin.
  • 5,911 Answers
Check the lid switch. As you open the lid, you should hear a clicking noise as the switch open and shuts. This is a common problem for this model washer. Make sure the plunger on the lid is still intact and not broken off. This is used to push down on the contacts of the lid switch. To prove the switch bad you can also remove the console and find the lid switch connector. Unplug the washer before attempting this. Disconnect the lid switch plug (white plastic connector). This is a three wire connector. You can take some alligator clips and short the outer two wires together (both black wires). Turn the washer back on. If the washer runs fine, you have a lid switch problem. If not, you may have a timer that is not advancing like it should. I hope this helps you. Let me know if you need further guidance.
Posted on Aug 17, 2007
  • 641 Answers
Check that the drain house is clear from kinked or clogged. Good luck!
SOURCE:
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
82 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
