Question about Palm Treo 650 Handheld
Keypad not working
Anytime I try to use the keypad or the navigation button on my treo, they won't work. They were working fine for a while, but now they don't function at all. I have tried resetting the phone. The only button that works is the button with the home symbol. Any suggestions? Thanks!
I am currently battling the same problem! The only key working on my keypad is the 'p' key, so I'm rather screwed. I've read many places online; however, that the problem is in the membrane underneith the keypad. Apparently it gets grimey or sand/dirt could get in it and it causes some of the keys to jam. You can purchase a new keypad here: http://performancepda.zoovy.com/c=1MywSpzr1JEqf54FSFslR8GzP/product/TREO650FLEXKEYBOARD if you're that interested. As for me, I'm prying the sucker apart to see if I can do it myself! Hope I was of help! xx Molee
Posted on Aug 31, 2007
SOURCE:
Menu button won't work
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Oct 31, 2012 | Samsung Cell Phones
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Hello sir/madam , in my nokia n70 device the left navigation key and the buttons 1 and 3 does not work . up and down navigation keys are also not working . kindly tell me the right solution
Hi Friend!
The best advice I can give is that you bring your phone to a technician for check up. You might not want to tinker with your device on your own and end up with a dead unit altogether but if you wanna give it a try, the problem somestimes is a dirty or corroded keypad. Remove the membrane attached to the keypad and use a cleaning solution such as a paint thinner to clean the keypad surface. Use a piece of cotton with the solution. Another thing you should also check is the keypad connector. Check if it is properly aligned.
Dec 19, 2010 | Nokia N70 Cellular Phone
Palm treo 680 keyboard does not work press any button and theres no response not even the on -off button
All the TREOs (6xx, 7xx) keypads are attached via a flat flexible copper-trace cable that sometimes simply gets loose from the phone's mainboard. This is a job for someone who is used to removing very small screws. Depending on the model there are either 4 or 6 torx screws to remove. Carefully try to pry (not pull all the way apart!) the front phone plate from the lighter silver-colored sides and when it gives only then slowly pull the back plate - the cable/connector should then be visible.
Oct 31, 2009 | Palm Treo 680 Smartphone
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with navigation keypad of Nokia 5200
good day,
have you tried opening your nokia 5200? if your confident and have the right tools, try cleaning the keypad of your phone, at the same time try realigning the keypads. however, you can refer your problem to a competent technician.
Sep 30, 2008 | Nokia 5200 Cellular Phone
Blackjack keypad not working
it could be that your phone could have goten bricked which means that it locks your phone aka virus its very comen with all this 3 party software or the software made your phone have a system error makeing you have no way of fixing it phones are hard to fix not like a computer so your phone maybe done.
Aug 18, 2007 | Samsung Blackjack SGH-I607 Smartphone
Palm Treo 650 Handheld Logo
66 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
