Question about Brother MFC 210C All-In-One InkJet Printer
How can I refill my ink cartridges myself?
The code on the side of the cartridge is LC41BK.
  • 1 more comment
  • Anonymous May 15, 2008
    refill ink cartridges
  • Anonymous Jun 17, 2008
    were do i put the needle in on my ink cartrige Lc41y [ BROTHER ]
  • cuzzy wuzzy Jun 29, 2008
    refill procedure for brother MFC210C
    Sergeant:
  • 390 Answers
Be brave and have a go, buy the correct ink refill for your selection of cartridges, the packaging on the refill kits will tell you if your printer is included. Once you find one for yours, instructions come with it. I think your cartridges have plastic ones don't they? Make sure when you fill with syringe you follow instructions very closely to avoid air bubbles and always run a clean when you put it back in. I refill all the time, and each time i refill (i get 7-8 refills each cartridge now the way i do it) i am saving $80.00 both cartridges. This can be most of a thousand dollars a year for me.
Posted on Aug 17, 2007
SOURCE:
I refilled my cartridge for x2650, its full, but doesn't print I refilled my cartridge with ink myself that i bought from Argos, now it is full of ink, but still shows the message that i must replace...
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
Aug 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
I installed a compatible Office Depot black ink cartridge to the brother LC41BK printer, however continue to get the message "no cartridge installed - lift scanner cover and reinstall cartridge.
patthomas55,
Many times manufacturers use a sensor in the cartridge to defeat customers using "compatible" or "refilled" cartridges. In many cases you can just cancel out or hit stop or cancel several times to make the printer ignore the warning. If this does not work you will have to purchase the original equipment cartridge to be able to use your printer. I would think that you should be able to return the cartridges in question for a full refund.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 30, 2011 | Brother MFC 420CN All-In-One InkJet...
How do i refill the ink myself cannon mp520
You need to reset or replace the ink level monitoring chip on these cartridges for refills to work. I know some refill kit sellers don't like to mention this to people before they buy the ink. Otherwise, I would recommend Cartridge World for ink refills because it can be messy to fill these cartridges and they always reset the chips for you.
Nov 09, 2009 | Canon MP520 All-In-One InkJet Photo...
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
You can't refill these cartridges yourself. Your printer remembers the serial numbers encoded in the electronics of the cartridges that have been in the printer. If your printer sees the same serial number in a row it will kick out the cartridge. HP printers don't use this same system to reject cartridges. I recommend Cartridge World refills or refills from anywhere that has a high turnover of these cartridges so you don't get one with the same serial number.
May 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Brother mfc210c
two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
250 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
