Question about ASUS Intel 440BX Chipset P2B-VM Motherboard
Help my motherboard won't boot because it says the keyboard is locked ,how do i unlock it?
  • drummerman Aug 17, 2007
    the site shows and tells me nothin ,now what?
    what jumpers go where there are 4 of them which ones do i move and what pins do they go on?
    Brigadier General:
  • 6,966 Answers
Hi, This motherboard has this feature. You may have to manually open or short 2 pins of the front panel connector in the motherboard located at the bottom/lower right. This is better illustrated at page 33 of the manual which is available at the Asus website. Hope this works for you. Good luck and kind regards.
Posted on Aug 17, 2007
  • Louie  Role
    Louie Role Aug 17, 2007
    "the site shows and tells me nothin ,now what?"
    you download the manual. It is in the site. The complete URL ishttp://dlsvr03.asus.com/pub/ASUS/mb/slot...
    "what jumpers go where there are 4 of them which ones do i move and what pins do they go on?"
    Refer to the diagram below as shown in page 33 of the manual.
SOURCE:
How do you remove the keyboard on a Sony Vaio laptop PCG-7192L
Let's see if this helps Tom,
1) http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-keyboard.html
2) http://www.youtube.com/watch?v=8BEcX_0KYIE
The Keyboard Cable STAYS attached to the Keyboard.
It disconnects FROM the motherboard's connector.
The Keyboard Cable has NO connector on the end. It is a FFC.
Flat Flex Cable.
One example of a Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The flat metal terminal bars MUST be aligned back in the SAME position, as they were originally.
For this reason you may wish to take a Sharpee marker, and make a mark on one side of the cable.
Then make a matching mark on the same side of the motherboard connector, BEFORE you remove the cable.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two pieces, but does NOT come completely apart!
The bottom part is larger, rectangular shaped, and is stationary to the motherboard.
It is the BODY.
The upper part is smaller, rectangular shaped, and is movable.
It is the Locking Bar.
ACCORDING to the video the Locking Bar is the Slide/Wedge type.
DO NOT use a metal tool as shown. One slip, and you can damage the motherboard! Geez!
Use your Fingernails, or Thumbnails.
The Locking Bar slides up. Up towards the LCD screen, or away from the Body.
It ONLY moves about 2mm. That is a little larger than 1/16th of an Inch.
IF, the Locking Bar is broken, or the Body, you are looking at
-> MOTHERBOARD REPLACEMENT!!
Hence why I am being so detailed.
More detail on unlocking this type of motherboard ZIF connector,
A) Locked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Unlocked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
There is another style of Locking Bar used, however.
The Locking Bar flips up to a 90 degree position, or also can be stated as Straight Up.
Just to make sure I'm going to include info for it too;
A) Locked position
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 28, 2012 | Sony VGN Computers & Internet
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Before Windows xp loadsi get a message to "unlock your keyboard" I cannot access my controlboard since xp will not load until I unlock the keyboard. I tried using a different keyboard but same message...
when booting hit f11fast and over and over til the setup options starts or f2 for the bios to pop up and route though til ya find the keyboard options ok if locked unlock or enable it, it is in one or the other or upon boot hit R many times til the recovery tool pops up and then do a HD error diagnostic on it to find the problem ok the fixist good luck and have a nice day
Jul 01, 2010 | Computers & Internet
My keyboard is completely locked,how do i unlock
locked how?
not working at all?
try turning PC off...disconnect and reconnect your keyboard and boot your PC back up
This fixes issues like this 9 times out of 10
Apr 09, 2010 | HP DC170B Keyboard
My computer keyboard is locked. How do I unlock
The connections might be loose. Please try to unplug the cable which connects your keyboard to the computer. If that doe snot work try an alternate keyboard and see if that works.
If that still does not work, then most probably it is the keyboard port on the motherboard which is faulty.
Apr 06, 2010 | Dell Dimension 3100 PC Desktop
Unlock computer keyboard
You can try updating the BIOS. Click HERE to get drivers, support and user's manual for your boar.
Jun 20, 2008 | Asrock P4I45GV R5 Motherboard
Want to change priorities of boot in BIOS
This link is for the owners manual on that board,
http://download.intel.com/support/motherboards/desktop/d850mv/sb/mdmvenglish.pdf
On page 47 it states F2 is used to get into the bios, press repeatedly while booting so you don't miss the window, and of course check you keyboard, it should flash the caps,num, and scroll lock lights on boot.
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Intel D850MV Motherboard
I'm confused
Did you checked BIOS , is there any option to change that
Aug 17, 2007 | ASUS Intel 440BX Chipset P2B-VM...
ASUS Intel 440BX Chipset P2B-VM Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
