Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
My monitor's white balance is all out of whack!
For some reason my monitor is glowing white fuzz over the entire display uniformly. The contrast and brightness are totally screwed up. I can still see the picture although I can barely do so without adjusting the contrast and brightness, and even afterwards the picture still looks like I have battery acid in my eyes. In order to properly read anything or see the mouse and cursor, I have to turn the contrast all the way down and turn up the brightness. I've updated the drivers for my graphics card (raddeon 9550) Tried using the catalyst control center software as well as adobe gamma to adjust gamma levels and brightness and contrast levels, and even tried using powerstrip (software that came with my alienware comp) and it's worthless. I'm assuming it's a hardware issue now for obvious reasons. I've checked the pins in the cable and they're fine. I'm out of warranty too, which is wonderful. So after all of this I'm thinking that my monitor is pretty much done for or that my graphics card is shot. I really don't want to bring it in and pay 100 bucks for someone to tell me to buy a new monitor. Please let me know if there's anything else I can do before I set this thing on fire and desecrate it's remains. Thank you so much.
  • dik12in Aug 20, 2007
    I checked the cable and made sure it was straight, but unfortunately the screen is still glossy and fuzzy. There wasn't any improvement. If you have any more suggestions please let me know. Either way thanks for the suggestion. Also is it possible that it's just the cable? Let me know, thanks!
    Problem Solver:
  • 9 Answers
Your problem is the connection to your cpu connect it propely and make sure it is STRAIT if the problem persists contact me
Posted on Aug 17, 2007
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
Monitor shuts down and glows pink
You could try updating the drivers for your monitor and for you video card. It sounds like their could be a hardware problem. When something warms/heats up the connection is made. A pink glow isn't a good thing. Make sure you check all cables and even try to adjust the actual monitor settings Your heat settings for the colors may be out of whack. Last question? Does slapping it a little help? Good Luck. Let me know what happens. Tim
Feb 19, 2007 | Samsung SyncMaster 750S 17" CRT Monitor
White balance metering
Cameras need a white reference for that measurement, they don't get it from the meter. On your camera (which I think works pretty much like my 10D) you can take a picture of a white card (white reference); the camera would use that frame to set its WB in AUTO mode (AWB). You can also safely guesstimate the K value with a little practice for cases in which a white card is not available or no other white objects are at hand. White Balance measures the light K value which illuminates a scene it doesn't measure the objects in an image. Further, in some cases you may have mixed lighting which makes matters slightly more complex. For example: if you are shooting under tungsten ambient light and want to use flash as a main or fill light you'll have to use a gel on the flash to match the ambient light and set the camera to that K value. This will give uniform light cast (color). However, for creative purposes, it's desirable occasionally to let one of the two light sources "shift". In the example just given, if you set the camera to a K value of 5600-5800 (around a typical flash K value) and use the flash without gels then, the tungsten ambient light would appear as shifted (redish, the typical tungsten colorcast when used with daylight film/wb) while the flash light would be balanced and not shifted. This difference (shift) would give the picture a different feeling.
Sep 14, 2005 | Canon PowerShot EOS D60 Digital Camera
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
