FixYa.com
Tags:
Casio Exilim EX-S600 Digital Camera
Wont turn on
posted by heth on Aug 17, 2007
pushing the power button and nothing happens.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 02, 2007
Thanks for Trying (70)
poolseman
Rank:Guru Guru
Rating: 89%, 242 votes
Check contacts inside battery chamber ( clean with pencil erasor )Second , fuse may be blown and is not expensive to replace ( situated same side as LED screen and is marked as fuse on the board ). But you will need proper soldering iron which does not get too hot and one with fine point.( and a tweezer )
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 06, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i only had to take the battery out of the battery chamber and then slide it back inside and my camera started to work. http://americanidolpixelmania.com/signup.php
Can you Help with these Digital Cameras problems?
Digital Cameras
My canon mv850i digital...
My canon mv850i digital... Answer This...
Digital Cameras
Strange winding -motor-like...
Strange winding -motor-like... Answer This...
Digital Cameras
the eyepiece you focas thru
the eyepiece you focas thru... Answer This...
cannot see through the monitor...
I put a new battery in my... Answer This...
cracked screen
where do i go for repairs.... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
