Question about Toshiba Tecra A8-S8514 Notebook
Unable to enable the touchPAD
I go to Control panel - Mouse Properties then the 'TouchPAD ON/OFF'tab. I select enable then 'apply. then 'OK' I then reboot and go back in and it has reverted to 'Disable' again? I want to get my touchPAD working - can you please help?
  • mudmud Aug 17, 2007
    Many thanks for your advice, but I have checked and its in the startup and it was already there.. Any other ideas?
  • Toshiba Master
  • 12,061 Answers
What you need to do is make sure this program is "Loaded" at startup... I think you may find an option of allowing the program to start with windows.. if not simply put the .exe in the "Startup" folder and it will then start with windows.. Otherwise go to the relevant web site and get the latest Driver and reinstall it... when doing so ensure it is set to be active at boot time.
Posted on Aug 17, 2007
  • electronic & computer repair&  servicre
    OK go to "Services" and see if it is set to "automatic" perhaps somehow it's been disabled there?
    Otherwise uninstall completely, reboot and reinstall, with ANOTHER version, a "Fresh" version from somewhere else. Make sure the "Driver" is the "Latest".
SOURCE:
Touchpad Scrolling
The scrolling feature on a laptop touchpad can take some getting used to, which causes some users to disable the feature.
Whether scrolling was intentionally turned off or never enabled on the laptop, it can easily be turned on from the "Mouse Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and select "Control Panel." Select "Classic View" in Vista if not already displayed. Double click "Mouse."
You may also access "Mouse Properties" in Vista and Windows 7 by clicking the Windows logo and typing "Mouse" in the search box.
Press "Enter," then click "Mouse" when the search is finished.
Select the "Hardware" tab.
Select the touchpad and click "Properties."
Click "Change Settings" if the settings aren't displayed.
Click the "Device Settings" tab in Windows 7 and select the touchpad.
Click "Settings."
Click "Virtual Scrolling" in the touchpad properties window.
Click the boxes next to each "Enable Scrolling" box and click "OK." Scrolling is now turned on for your touchpad.
May 26, 2013 | ZT Group Cisnet PC Desktop
How do i scroll with touchpad in sony vaio vpccw21fx
Step 1:
The scrolling feature on a laptop touchpad can take some getting used to, which causes some users to disable the feature. Whether scrolling was intentionally turned off or never enabled on the laptop, it can easily be turned on from the "Mouse Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and select "Control Panel." Select "Classic View" in Vista if not already displayed. Double click "Mouse." You may also access "Mouse Properties" in Vista and Windows 7 by clicking the Windows logo and typing "Mouse" in the search box. Press "Enter," then click "Mouse" when the search is finished. Select the "Hardware" tab. Select the touchpad and click "Properties." Click "Change Settings" if the settings aren't displayed. Click the "Device Settings" tab in Windows 7 and select the touchpad. Click "Settings." Click "Virtual Scrolling" in the touchpad properties window. Click the boxes next to each "Enable Scrolling" box and click "OK." Scrolling is now turned on for your touchpad.
Feb 25, 2013 | Sony VAIO VPCCW21FX Notebook
How do I enable my touchpad scrolling feature?
Right-click on the desktop, then click "Personalize."
Click "Change mouse pointers." This opens the mouse properties window.
Click the "Gestures" tab in the mouse properties window.
Click the "Use Vertical Scroll Function" and "Use Horizontal Scroll Function" check boxes.
Click "OK."
or you might
click "Start" button in the lower left corner of your desktop.
Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
Sep 01, 2012 | Dell Inspiron 1520 Motherboard
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
I have a toshiba laptop the mousepad won't move.
First connect a mouse to your laptop. Click "Start" and open the control panel, click printers and other hardware and then click "mouse". Under mouse properties, click the "device settings" tab. Under the device window, you can see if the touchpad is enabled or not. If it is not enabled, click on the enable button.then click "apply" of "ok" button. Your touchpad should be working again.
Sep 07, 2010 | Computers & Internet
THe mouse on my lap top is locked .how can i unlock it
The TouchPad is enabled by default. To change the enable/
disable TouchPad setting by using the Fn + F9 keys, see
“Disabling or enabling the TouchPad” on page 234.
You may also change the enable/disable setting as follows:
1 Click Start, Control Panel.
The Control Panel window appears.
2 Click Printers and Other Hardware.
3 Click Mouse.
The Mouse Properties window appears.
4 Click the TouchPAD ON/OFF tab.
The TouchPAD ON/OFF tab view window appears.
5 Select Disable or Enable, whichever is appropriate.
6 Click Apply.
7 Click OK.
The Mouse Properties window closes.
8 Close the Printers and Other Hardware window.
9 Close the Control Panel window.
Or you can get the manual on the link below. Just type in the # code and click on download now. Page 61 tells you how to unlock the mouse pad.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Toshiba Satellite A15-S157 Notebook
Toshiba M35 S320 touch control buttons have stopped working. How do I fix it?
The TouchPad is enabled by default. To change the enable/ disable TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click the Mouse icon. 4 Click the TouchPAD ON/OFF tab. The TouchPAD ON/OFF tab view window appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply. 7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window. 9 Close the Control Panel window.
However, still if it does not work, you need to download drivers for touchpad.Here is link to download the drivers for touchpad. Under the "All categories link choose Touchpad"
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556040&rpn=PSM30U&modelFilter=M35-S320&selCategory=3&selFamily=1073768663
Mar 27, 2010 | Toshiba Satellite M35-S320 Notebook
My toshiba touchpad is not working
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is enabled. If it is not, then change the setting to enabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
Nov 02, 2009 | HP Pavilion dv4000 Notebook
Not working.
Oct 31, 2009 | Dell F3534 Touchpad
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Tecra A8-S8514 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
