Question about Microsoft Xbox 360 Console
Error disk reading Xbox 360
Hello, I purchased a used Xbox 360 with 2 games. One game is working fine,but the other one PGR 3 does not load. I would like to know what's the problem and how can I fix this problem. Thanks
You can try a 3rd game and see if it loads and if so then there is a problem with PGR3 and not with game. Also clean with alcohol and try again
Posted on Aug 17, 2007
SOURCE:
Mass effect 3 wont start on my xbox
Hello,You should replace your disc. May be your disc might have some error. Contact the store where you purchased your game and ask them to offer you a replacement Gaming disc immediately.
Nov 11, 2017 | Microsoft Xbox 360 Elite Console - Black
Will not read xbox 360 games and will not load
This is a common issue.
1. Make sure your disk is clean. Dirty disk can cause disk reading issues.
2. Clean the drive with a CD/DVD laser cleaner.
3. Replace the laser. You can get a replacement from Ebay for $10-15. Make sure you get the right one for you drive. There are several different models.
Jun 01, 2010 | Microsoft Xbox 360 Elite Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Brand new 360 elite will not play nba live 09 ONLY
ok , if it is giving u the open tay error , every time u try and load it , it could be a number of reasons behind it , i had the same problom , most games will play but i had 1 game that no matter how many new copys of the game i got , when i put it in my xbox the game spun 3 times and then said , open tray , like trhere was no game in the xbox, so i went 2 you tube and typed in open tray error xbox 360 and there r loads of examples on how 2 fix it , if u keep opening and closing the tray each time after it says open tray after about 6 to 7 times , it should play , but i would go 2 you tube , becase u need 2 open your disc drive 2 fix the problom.
Jan 13, 2010 | Microsoft Xbox Console
Assassin's Creed 2 won't load on Xbox 360
Sounds like your cd drive is not reading the discs properly. If that's not the problem, then you have a scratched disc on your hands.
Do what I did. Go to sellitbroken.com and sell your scratched/non-working game to them. They will give you good money for it.
Jan 01, 2010 | Ubi Soft Entertainment Assassin's Creed...
Xbox 360 won't read a certain game It reads all games fine except Halo 3, tried 2 copies, tried them in my friends xbox 360 and they both work, GTA 4 PGR 2 MotoGP saints row, works just not the game i...
If you have the original X box CD's it will work fine expect when you have issues with region code.PAL NTSC are the two format a game can work with.so if you have NTSC formated game TRY a PAL version.it may work.
else clean your lens and try inserting a new CD of that GAME.
Jun 12, 2009 | Microsoft Xbox 360 Console
Games unreadable for xbox 360
Sorry but it sounds like you need the drive replaced. We offer the lowest prices available for this type of service. Email us with drive type for free estimate. [email protected]
Jan 27, 2009 | Microsoft Xbox 360 Console
Gears of War 2 Loads but says "disk unredable."
You have a problem with your Xbox. 3 Game discs arent all faulty.
Call a service agent and tell them your Xbox cannot read discs.
Jan 04, 2009 | Microsoft Gears of War for Xbox 360
Disk Scratched By Xbox 360
Lazer burn!!!happens to a load of my discs too usually doesnt kill em though
Mar 26, 2008 | Microsoft Xbox 360 Console
Cannot read disk error
Heres what you need to do:
1.Call 1800-4myxbox see if your still under warranty.
2.If you like, I do not think its nessary, get them to replace your current 360.
What 95% of the time causes the 360 to damage teh disk is when your system is *VERTICAL* (up and down) or if you move the console while your playing it, or if the console got knocked over while a game is playing.
From now on put the console horizontal, this will prevent the scratching of games.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
116 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
