Question about Danby DWM5500 Front Load Washer
Washer doesn't go to high spin
It will drain, but the clothes are wet becuase it doesn't go into high spin. I'm going crazy
  • Bedowin Aug 17, 2007
    No... it doesn't. It was working just fine until this last load. No settings were changed, but then again, it's a basic machine and only has basic settings.
Junk it! Worst washer I ever had!!
Posted on Jun 06, 2008
I have a Malber and you can set the RPMS have you tried increasing that?
Posted on Aug 17, 2007
  • abgymnic Aug 17, 2007
    I am sorry I am new to the all in one units and thought it would help :(
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
May 26, 2012 | KitchenAid KAWS850L Top Load Washer
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Danby DWM5500 Front Load Washer Logo
64 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
